cracked head?
Stewart
My 75 has had a habit of drinking water. Over christmass when I was last home I found a bad radiator cap and dco forgot to tighten up the heater hose to the heater valve. I fixed the 2 leaks and drove it another 100 miles or so where it then drank more water than I've seen before close to 1/2 gallon. Prior to this it used about that same amount over 1k miles. Car was still running a couple needle widths to the left of the N.
The oil is super clean and clear none of the normal gack under the cap. I refilled the radiator opened up the heater valve and topped off it off after the t stat opened. However with the cap off the water was fizzing like a coke in a glass after 5 minutes after pouring it with a big bubble every once and while.
Should I be planning on pulling the head next week when I'm back or should I be looking for another external leak?
Steve_S
Could be a head gasket as well. Either way it sounds like a bit of work is in your future. I'd suggest a compression test.
What I would rcommend is a pressure check tester, it's device that hooks up to your radiator cap and you pump it up and if the system holds pressure it will show it on the gauge of the tester, then you're ok, and if not you have a problem, if the leak in the system is external, then you liable to see as well.
Bob_s
if you rule out external leaks per haps suggestion you could swing by your favorite repair shop and have them put the sniffer from an exhaust analyzer right at the radiator neck(not in any coolant). any co/ hc there and you'll have to pull the head. that's saved me a ton of time searching overheationg problems in the past. hope it helps
Sebring222
The good news is that in all likelihood you do not have a cracked head. Leaking water pump, heater core,
hoses, or radiator core are all good suspects. Do you smell coolant at shutdown? This would be a good indicator if it is a simple leak.
Jim D
There's also a more modern test for testing for a blown head gasket, it was just becoming popular when I got out of the general automotive repair business. The test uses a liquid, that when mixed with your coolant will turn colors if there is presence of carbon monoxide.
Stewart
Stewart
Finally got my hands on it. No external leaks compression was 130 120 105 130. Looks like I'm going to have some fun on friday.
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
M cracked head ??? Triumph 6
Carlos TR4/4A TR4A cracked cylinder head Triumph 8
tweety It wasn't a head gasket or anything cracked..... Spridgets 1
tweety I'm assuming head gasket, cracked block or head??? Spridgets 4
SilentUnicorn 1500 Cracked head? Spridgets 3
P Cracked windshield Other Cars 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
P TR2/3/3A Windshield Cracked Triumph 12
Kleykamp TR2/3/3A Cracked Block??? Triumph 6
D MGB MGB Cracked Cylinder Heads Question MG 4
TimK 2 cracked windshields Austin Healey 13
aeronca65t Cracked Rostyle Spridgets 6
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
MCNX_BFF Cracked and leaky Triumph 20
eschneider MGB MGB sunvisor rivets [and now cracked glass] MG 4
Baz Cracked coil spring! Spridgets 25
B Piston is cracked MG 7
U cracked exhaust manifold Spridgets 19
G TR2/3/3A TR3A cracked frame Triumph 3
J cracked wishbone! Spridgets 17
J New Soft-top, or reupholster cracked window? Triumph 6
G Quarter Light Frames Cracked! MG 0
M TR2/3/3A Cracked TR3 block... Triumph 0
N TR2/3/3A TR-3A cracked exhaust manifold Triumph 8
M TR6 Help- TR6 rear shock mount cracked Triumph 3
aeronca65t Cracked WIndshield Restoration & Tools 15
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
