TR4/4A TR4A cracked cylinder head
Carlos
Member
I am having trouble locating a rebuildable cylinder head for my 67 TR4a, so I am considering repair. The crack is in the perpendicular to the crankshaft and in the middle of the head between #2 and #3 cylinders.
Are there any resources out there for repair, or any suggestions for a rebuildable used one?
Thanks.
TR3driver
Great Pumpkin - R.I.P
If this is in the web between the two water jacket holes, then I'd suggest just leaving it alone. They frequently crack there, but with water jacket on both sides of the web, there is no place for anything to leak.
MDCanaday
Randal is on this, if its just the little web between the center jackets forget it and worry about something serious.
MD(mad dog)
vivdownunder
But if it happens to be elsewhere, the people I've used are Metalock who use a metal stitching process. Last TR head I had repaired was cracked in 8 places and it gave no further trouble for the remainder of the time I had that car.
I think it's a USA developed technology licenced for use here, so you should be able to track them down OK.
Viv.
Carlos
Carlos
Member
Thanks for your comments and the welcome. You've given me a few good leads to follow up on Monday. I'll also take a closer look at what I got and think about where the spider crack may be going... leaving well alone sounds like an enticing possibility!
Geo Hahn
I was surprised to find stitching in my TR4 head when I had it off for hardened seats. It did not say 'Home Sweet Home':
The trusted machinist who was doing the current work pronounced it a old & very sound repair and said not to worry (and I don't for the 4 years since).
Paulus
I had my TR6 head repaired the same way by a local machine shop last year. It was more cost effective than buying a replacement head and has corrected the lost compression issue. Buying a used head sight unseen may bring you new challenges.
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
