6 cyl aluminum head - cracked valveseat
BoyRacer
I just discovered that the cylinder head on my race motor has a cracked valve seat. It is the 6 cylinder aluminum head with the figure "8" style of valve seats. The casting number on the head is AEC 721. Has anyone successfully replaced or repaired one of these seats? Anyone out there had any experience with this issue? Anyone with with a spare bare aluminum head?
Louie Aluminum 4 cyl head Austin Healey 9
S Spitfire Cyl head coolant hose fitting Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
Tiger2Dan For Sale Convert your 4 cyl to a V6 Other British Classifieds 0
K TR2/3/3A Plug Weld CyL Head Triumph 10
W Clutch slave cyl. Austin Healey 4
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
RJS TR4/4A Beginning Cyl Head Removal - Questions Triumph 21
George Zeck Master Cyl Leaking .... Spridgets 5
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
S TR4/4A Oil in Cyl # 1 Triumph 14
jlaird Master cyl rebuild Spridgets 9
tahoe healey Clutch master cyl. push rod Austin Healey 2
M stripped threads on master cyl Spridgets 12
angelfj1 TR 4-cyl exhaust manifold to cylinder head nuts Triumph 4
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
A another master cyl question Triumph 4
Johnny Spitfire How to rebuild a Spitfire 4 cyl engine in 45 sec. Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
J TR6 TR 6 Slave Cyl Mounting Triumph 12
K TR2/3/3A TR3 83mm Cyl Liners bored out to 87mm? Triumph 2
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
J Looking for the right 4 cyl engine to produce 200 Racing 19
B Brake m/cyl diameters for race set-up? Racing 7
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
TonyPanchot Head porting 6 Cyl Triumph 23
B Brake/Clutch Master Cyl. Spridgets 8
R low compression on one cyl, but steady vacuum read Spridgets 15
G cyl head torque specs Spridgets 5
P removing clutch master cyl. impossible? Spridgets 4
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
RedTR3 TR2/3/3A TR3 Clutch Slave Cyl Return Spring Size? Triumph 7
T master cyl, leak Triumph 3
R T-Series 74 B clutch master cyl MG 7
F Stag Stag clutch slave cyl Triumph 2
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
dingleberry3343 1974 MG Midget Brake Master Cyl. Spridgets 3
HealeyDave Cyl Head Stud Replacement Austin Healey 6
B BE Master Cyl Spridgets 6
J 1275 Cyl Head volume question Spridgets 2
R Master Cyl Rebuild MG 8
michalotti_tr 6 cyl Engine Mods Triumph 41
jlaird Info - master cyl rebuild Spridgets 4
A MGB MGB Brake M/Cyl...Made in China MG 9
jlaird Cooper cyl head maybe on ebay Spridgets 7
P E-Type 6 cyl Engine Rebuild in San Diego Jaguar 4
