TR 4-cyl exhaust manifold to cylinder head nuts
angelfj1
Some discussion here yesterday concerning the "tall" nuts which secure the exhaust manifold to the cylinder head. Some say steel nuts on copper plated steel studs, others say always copper/bronze nuts, yet other say steel nuts originally but later changed to bronze.
Any comments?
:smile:
TR3driver
Great Pumpkin - R.I.P
Well, the part number for the nuts was the same from TR2 through TR4, so I don't think they changed. My belief is that they were always tall steel nuts; the occasional tall brass nuts are aftermarket (sold for a Chevy V8 as I recall).
Not sure about the copper plating, but I've never noticed any evidence of it. I use a copper-based anti-seize though, so maybe I wouldn't have noticed plating even if it were there.
As a side comment, it has been my experience that adding a heavy flat washer (aka "setup" washer) to the two outermost studs (the ones without the bridge piece) helps to keep the joint sealed. The lockwashers need to be replaced pretty much every time a nut is removed (apparently the heat cycling makes them lose tension). And a 'swivel' socket makes it easier to retorque the nuts occasionally, which will also help keep the joint sealed.
Geo Hahn
Always hard to form an opinion unless you've seen several possibly original TRs... too easy to think 'Well, mine is correct'.
My TR3A hade the tall steel except for a couple of ordinary nuts. I tried to replace the latter with tall steel and was unable to find any -- suggesting to me that the tall steel were original. In the end I replaced the short nuts with some tall brass cut down to the length of the tall steel -- you'd have to be pretty nosy to see they are different.
My TR4 is pretty much an original car but had the short steel nuts there. However, I have determined that the head had been drastically repaired/rebuilt -- possibly at the factory -- so those nuts are not necessarily as original.
TR4nut
Tall steel nuts on copper plated studs - just like the ones on the red 3A next to yours :smile:
Ps I haven't given up on my argument on the choke linkage either!
PeterK
The replacement studs I purchased for my 4A years back were copper colored. High temp copper anti-sieze is a must when assembling.
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
S Spitfire Cyl head coolant hose fitting Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
Tiger2Dan For Sale Convert your 4 cyl to a V6 Other British Classifieds 0
K TR2/3/3A Plug Weld CyL Head Triumph 10
W Clutch slave cyl. Austin Healey 4
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
RJS TR4/4A Beginning Cyl Head Removal - Questions Triumph 21
George Zeck Master Cyl Leaking .... Spridgets 5
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
S TR4/4A Oil in Cyl # 1 Triumph 14
jlaird Master cyl rebuild Spridgets 9
tahoe healey Clutch master cyl. push rod Austin Healey 2
M stripped threads on master cyl Spridgets 12
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
A another master cyl question Triumph 4
Johnny Spitfire How to rebuild a Spitfire 4 cyl engine in 45 sec. Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
BoyRacer 6 cyl aluminum head - cracked valveseat Austin Healey 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
J TR6 TR 6 Slave Cyl Mounting Triumph 12
K TR2/3/3A TR3 83mm Cyl Liners bored out to 87mm? Triumph 2
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
J Looking for the right 4 cyl engine to produce 200 Racing 19
B Brake m/cyl diameters for race set-up? Racing 7
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
TonyPanchot Head porting 6 Cyl Triumph 23
B Brake/Clutch Master Cyl. Spridgets 8
R low compression on one cyl, but steady vacuum read Spridgets 15
G cyl head torque specs Spridgets 5
P removing clutch master cyl. impossible? Spridgets 4
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
RedTR3 TR2/3/3A TR3 Clutch Slave Cyl Return Spring Size? Triumph 7
T master cyl, leak Triumph 3
R T-Series 74 B clutch master cyl MG 7
F Stag Stag clutch slave cyl Triumph 2
dingleberry3343 1974 MG Midget Brake Master Cyl. Spridgets 3
Louie Aluminum 4 cyl head Austin Healey 9
HealeyDave Cyl Head Stud Replacement Austin Healey 6
B BE Master Cyl Spridgets 6
J 1275 Cyl Head volume question Spridgets 2
R Master Cyl Rebuild MG 8
michalotti_tr 6 cyl Engine Mods Triumph 41
jlaird Info - master cyl rebuild Spridgets 4
A MGB MGB Brake M/Cyl...Made in China MG 9
jlaird Cooper cyl head maybe on ebay Spridgets 7
P E-Type 6 cyl Engine Rebuild in San Diego Jaguar 4
