TR4/4A Oil in Cyl # 1
spbvmb
Member
I have a TR4 with 2000 miles on professional rebuild. The engine suddenly started to burn oil with pretty good exhaust cloud. Checked compression which is right where it always is at 175 and matches other cylinders. Plug from #1 is very oily and spinning engine without plug blows oily smoke out plug hole. One would expect the usual valve guide, ring, cracked head, loose wrist pin, etc would compromise the compression. Stuck ring would be best guess. Awaiting suggestions.
Thanks, Phil Brooks
TR3driver
Great Pumpkin - R.I.P
Valve guide problems usually don't cause low compression readings. I'd be checking if perhaps your rebuilder used intake guide seals (not original) and one has come loose. Also lose the external rocker feed, if one has been fitted (which would be why the seals were needed).
Everything else I can think of (including a stuck ring) would cause low compression, unless perhaps there was just enough oil in the cylinder to match the (unoiled I assume) results from the other cylinders. Pressurizing the cylinder with air (eg a leakdown test) might tell you more.
S
spbvmb
Member
TR3 Driver. Thanks for your suggestions. The part of the puzzle for me is that this engine has never burned any oil nor any smoke from exhaust. Then from one minute to the next poof, out comes the smoke. Wouldn't a valve guide were slowly. There is plenty of oil on top of head.
Phil
TomMull
It is very easy to overlap the expander on the 3 piece oil rings. The symptoms are as you describe; oil in one (or more) cylinders, little or no effect on compression, smoke from that cylinder. Don't ask how I know.
Tom
TR3driver
Sure, which is why I was suggesting a seal that became dislodged. That can happen from one stroke to the next. BTDT
TR4nut
+1 on what Tom said on the oil control ring. One of our club members experienced the same issue.
TR3driver
But did it suddenly start burning oil 2000 miles later? Seems like an incorrectly assembled oil ring would cause problems immediately, rather than after some 50 hours of operation.
TR4nut
Actually yes it did - not sure why but perhaps the spring shifted after some use.
Rut
Is your engine equipped with a PCV valve? If so, you might have a bad diaphragm that's allowing excessive oil into the intake causing what you describe. Check the easy/cheap things first...hope that's it.
Rut
TR3driver
DornTRoriginal
Can you explain more about why the ERF should be removed?
S
spbvmb
Member
Interesting, thanks!
OK guys I found the problem. My "oil" was a mixture of fuel and antifreeze. Blown head gasket shorted out the plug and made an oily like mixture. No indication of coolant in oil but will change anyway. I learned a lot from all your suggestions.
Thanks for your help,
Phil
Rut
Phil,
Happy to hear you found a relatively simple issue...much better than the alternatives!
Rut
TR3driver
IMO it puts way too much oil on top of the cylinder head. The rocker assembly is not designed for full oil pressure (and doesn't need it under normal conditions). Might not hurt on a fresh motor, but with a bit of wear it will put more oil past the intake stems, and rob oil from the rod & main bearings (that do need it).
Those Standard-Triumph engineers didn't design that clever oil metering mechanism just because they were bored!
TomMull
Phil,
Rut
Good news as long as you find and fix whatever caused the head gasket failure. Tom
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
L Oil Pumps Austin Healey 6
