TR2/3/3A Balancing TR3 Fan Assembly
Tinkerman
So. I read in the manual that the fan assembly is balanced as an assembly and if you replace any parts it has to be rebalanced on a jig. Any one out there have any idea how to do this?
I have mostly all new parts and a NOS fan blade and one balance piece. Wot to do? Wot to do?
Thanks, Tinkerman the Confused
Banjo
I don't know, But I'd be very intrested in an answer to this one, as I've never gotton one before. I think I have all the balancy bits for mine, but They were taken off before I got the car so I coulden't index them.
Anybody? Anybody?
NutmegCT
Just taking a stab at this ... how 'bout balancing like you balance a lawn mower blade. Hang on a nail and keep adding or subtracting weight until it doesn't tend to turn by itself.
Tom
MGTF1250Dave
I would think Tom's method is as good as most (especially since I don't have an alternative one). I think the fan needs to be mounted on the hub extension and you could use the crank/mounting bolt as the "nail". Spin the assembly and theoretically the heavy side will always at the bottom. If the blade pointing down is always random, it should mean that it is balanced.
If there is shop near by that builds drive shafts, they may be able either do the job or give advice.
FYI, after they were balanced at the factory, a small hole was drilled through the fan, hub extension, etc so it could be reassembled. Aligning as many of these holes that you have might be a good starting point.
Don't forget to re use or replace the crank bolt locking plate.
TRopic6
You know, I bought a lawnmower balancing device a while back with that in mind. Now it's packed away somewhere, but it was a grey stepped plastic cone set on top of a pin. The idea is to place the blade on it with the cone in the center hole and file off weight until it sits level. Hopefully you can arrange those half-circle balance pieces to make the fan sit flat. I bet you can get one at Home Depot.
Howzit, Dave!
Jeff
74 TR6 CF13816U
Banjo
I thought of that... That's basically the same thing as an old bubble balancer for tires. But a smaller one for mower blades would be better. Good idea
AweMan
Balanced ............. Hmmmmmmmmmmmmmm ............ when I got my TR-3 It had been hit in the nose, bent the bejeebers outta the radiator and fan blade I managed to find a used radiator {this was back in about 1964} anyway ... I had NO idea that this assembly had/needed to be balanced. I took a hammer to the fan blade and reshaped it the best I could and bolted it back on the engine. I`v been running it this way for quite some time now {well at least until I decided to do this last restoration,} In any case I`v ran the engine with the fan in this manner for quite a time and it never seemed to be of any consequence as to the proper running/cooling of the engine.
I had NO idea that it was supposed to be balanced.
Oh well!
My latest plan is to remove both the fan and extension hub completely and use an electric fan setup.
That little four bladed fan never was much to the affect of cooling things off at slow speeds and especialy in traffic stop and go situations.
Hopefuly I won`t run into any S.N.A.F.U.`s In trying to go with electric.
Tinkerman TR2/3/3A Balancing a TR3 fan assembly Triumph 7
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
HealeyRick Proof of Concept - Drum Balancing Austin Healey 21
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
HighAltitudeTR3 TR2/3/3A Balancing Wire Wheels... Triumph 4
parkerg1 TR2/3/3A Balancing Wheels Triumph 13
vette Wheel Balancing Beads Austin Healey 3
PAUL161 T-Series Balancing Drive Shaft MG 4
N Wheel balancing?? Spridgets 5
PAUL161 General MG Wire wheel balancing service MG 2
S TR2/3/3A Wire wheel balancing Triumph 16
CJD TR2/3/3A Crank balancing Triumph 11
tahoe healey DYI wheel balancing Austin Healey 1
D Balancing Beads For Tires Spridgets 6
RJS Balancing a radiator fan[?] Triumph 18
D Balancing Beads Austin Healey 32
mrdibbles Balancing Wire Wheels - While mounted on the car Austin Healey 18
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
L Balancing wheels and cowl shake, part 27 Austin Healey 5
RAC68 Wheel Balancing Hub Adapter Austin Healey 5
roscoe Tire balancing beads Austin Healey 4
J Balancing Wire Wheels - Old Method? Triumph 3
P Wire Wheel Balancing Triumph 7
pjsmetana Prop Shaft Balancing Triumph 12
PSJ Seattle area wire wheel balancing Spridgets 3
R Engine Balancing ? Triumph 11
G Trouble balancing steel wheels on '79 Spridgets 2
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
davidk TR6 TR-6 Flywheel balancing Triumph 1
D Balancing Connecting Rods Triumph 17
angelfj1 RoadForce Tire Balancing I Don't Understand??? Restoration & Tools 4
58Custom What are the tricks to balancing wire wheels? Spridgets 8
Geo Hahn Tyre Balancing Triumph 13
tahoe healey wheel balancing Austin Healey 14
NutmegCT H6 carb balancing Triumph 8
zimmy Carb Balancing Tool Spridgets 7
Darwin A Balancing Act Triumph 1
prb51 Balancing Act Triumph 1
R Wire wheel balancing Triumph 10
A Carburetor balancing MG 7
M fan balancing Triumph 3
T Wire Wheel Balancing Triumph 8
A SU balancing on BJ8's Austin Healey 4
Randy Forbes Balancing Carbs... Austin Healey 3
T Balancing wire wheels Triumph 4
Bob McElwee Wire Wheel Balancing 'Adapters". Restoration & Tools 2
B Source for SU balancing tool ? Restoration & Tools 7
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
