Thanks everyone for your wishes,
So the motor wasn’t started today. I decided to cap off the vacuum line to the brake booster in case of back firing, which required a drive to the speed shop for parts. While I was at it, I also purchased some vacuum fittings for a gauge on the console. I was going to leave that for later until I realized the fuel rail had to come out to install it. Better to do it before the gas goes in.
Everything went well though. No leaks from the radiator, no fuses blew when I hooked up the battery. Fuel pump does its thing (though rather loudly). Starter makes noises (not bad ones so far). I didn’t really crank the motor since I still need to add oil. Even the dash lights and radio have life.
The day began with a good omen. As I was heading out for coffee, the UPS guy came up with the last K&N air filter I needed. I had been told that it was back ordered from Europe and to expect it towards the end of June. Wow, something actually delivered 5 weeks ahead of time, how often does that happen? Don’t know how well I’ll sleep tonight.
