Hey I am home and hip deep in Triumph projects.
I went to install the new upper wishbone bushings and the wishbones are installed opposite ways from each other.
I have a picture at https://s225.photobucket.com/albums/dd50/Norton47/Engine%20Pull/
This is the left side. It is assembled in the photo to match the right side. This is the way the right side is currently. When I took the left off it was reverse to the photo. That being the mounting ears with the longer distance were on the inside. Not the outside as they are in this photo.
Are they suppose to be different or the same. It goes back together easier this way clearance wise and was a pain to get out the way it was installed.
With them installed reversed wouldn't it cause different geometry when compared to the other size?
