TRclassic3
I've been fighting an annoying leak on the front carb. Made multiple attempts to remedy using the existing cork re-soaked in oil, new cork soaked in oil, "leak proof" O rings. I think I have finally defeated it by using 2 O rings at each packing point. Question is this, the upper jet bearing does not come up to even with bridge. I believe it used to, or at least closer to it, but I don't see any reason that it would not now. I should also mention that I replaced the upper jet bearing, brass washer, the jet tube and the needle as part of my effort to resolve the leak. Thoughts?
