I am restoring a 1954 TR-2 and am working on the front suspension. I am replacing both upper wishbone ball joints. The right one went on fine and I was able to tighten the nut. The left one is a problem. It will not tighten, the nut turns until you hit resistance. Then, the pin in the ball joints just turns and will not tighten. There does not appear to be a way to hold that pin so you can tighten the nut.
Should I assume the new ball joint is bad, as it is way to loose to ever think about driving with it.
Dick
Dick
