Windshield sealer
oldman
Group - any thoughts on using/not using a silcone sealer along the windshield to body seam? The rubber seems pretty tight to the metal but the Haynes Retoration book recommends this step. I didn't see any sign of sealer from the factory when I took the windshield off..
Thanks!
Don't use silicone. It'll be a PITA to get that crud back off if you or the next owner decide to restore her again. I can't remember what it's actually called but the other windshield thread a few posts down lists it.
jgbowman1
I used a 3M product in a caulk tube the paint shop recommended. It looks like tar, is non-hardening, and cleans off paint with wax and grease remover or naptha.
dklawson
If you decide to go with silicone sealant, don't use the regular hardware store stuff. Permatex makes a product called "flowable silicone" sealant. It's a clear silicone that is thinner than regular products to seep into crevices. Once cured it is softer than regular RTV and much easier to remove. Like Kenny said, the regular stuff is difficult to remove.
I've used 3M stuff that you had to pump in under the gaskets using an applicator kind of like an oil can. The stuff made a royal mess of (and discolored) the paint. I'll never use it again. I hope the "caulk gun" material is better.
See:
https://wwww.shop.com/product/Permatex_Fl...be/17017536.htm
tony barnhill
Great Pumpkin - R.I.P
If the rubber is good, there's no need for sealer
D TR6 TR6-windshield frame to bady sealer Triumph 3
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
steveg Rebuilding roadster windshield Austin Healey 24
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
Z TR2/3/3A Windshield Aftermarket Triumph 22
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
D TR2/3/3A Windshield difficulties Triumph 24
Rut Cut down windshield Spridgets 22
R Windshield Washer Pump Repair Austin Healey 9
M BJ8 Windshield Austin Healey 10
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
Rut Windshield rubber seal Spridgets 6
C Removal of windshield posts from my 100-6 Austin Healey 7
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
P Rivets on windshield and vent window frame. Austin Healey 1
DrEntropy E-Type windshield FYI: Jaguar 1
JPSmit Windshield and Wheeler Dealers Restoration & Tools 11
R TR2/3/3A Putting windshield back together Triumph 13
D TR5/TR250 Windshield wiper motor Triumph 9
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
