Hi all,
Progress on my '30 boxes of stuff', and a 1973 Midget body shell contiues to progress. Finished up fuel lines today! I went to the Pittsburg Grand Prix British Car Day yesterday, and "Bud" was kind enough to let me rummage through and around his 1972 on display! This let me go home and properly place my lines. It sure makes a difference to have a car on hand to look at while you work on things! Put in a Carter fuel pump, (I ordered a 2nd one to place in line as a back-up. I know I probably don't need a back-up, but while its all clean and fresh I thought I would put one in with a ancillary toggle switch up front). Placed new brake lines a few days ago, and carpeted the trunk.
Whats next is the windshield. I put on new rubber seals, sides and bottom, and replaced the glass (what a job that was!!!!!). So far, so good.
Today my son helped me place the windshield on the body.....you can guess where I'm going with this? The bottom rubber seal (windshield frame to body), is stiff and unreasonable! Will not 'sit down'. It keeps the frame a good 1/2 inch above the car. Applying great pressure, I can force one corner nearly down enough to get a bolt in. Is there a better suggestion?
Any good tricks to getting the windshield frame bottom rubber to settle itself down enough to be able to put in the side post bolts?
As always, thanking all in advance.
