TR2/3/3A TR3 Frame Kit
Gordo
I just got my kit for my 3 from Revington.
[/img]
The top pieces gusset the engine mount.
The next 8 pieces gusset the lower fulcrum and plates.
The 2 gussets go over the rear front spring mount pin.
The next 8 pieces gusset the shock mounting plate.
The next 8 gusset the rear spring tube.
The brake line bracket is much heavier than stock.
The kit is complete and the instructions are fairly clear. I think it is more expensive than it needs to be, but I quess I paid for the R&D which is ok with me.
Those two Y shaped pieces are not used on a 3 frame. They are for a 4 with R&P. If somebody can use them, PM me because I have no use for them.
Gordo
NickMorgan
Is this a strengthening kit for rallying?
Revington do seem to be expensive, but they are well worth it as their parts are excellent.
Nick
Tomster
So.... When you weld these into place, how do you jig or freeze the frame into the position(s) and arc(s) that you'd like? If you weld on a frame hoist theoretically you will arc as "centre high", if you weld with a tire style hoist you will weld and "centre flat or low"
Does the kit come with frame support blocks and instructions on placement of the blocks as well as specs?
G
Gordo
The kit is the base line kit for fast road. It omits quite a few longitudinal pieces recommended for a rally car. The kit is the same one mentioned in Roger Williams book. Neil Revington also recommends this slight upgrade for road cars.
I'll be installing the kit on a bare, naked frame which Revington recommends. The more advanced upgrades are suggested to be installed at their shop. That's not happening!! I quess if someone had the need and the skill, which I don't, could load the frame as Tomster mentioned but I'm not a racer.
My original frame was toast and the kit addresses each spot where my frame needed attention. I bought it more as an insurance policy for my replacement frame.
Gordo
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens For Sale TR3 Free frame Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame repairs recommendations Triumph 29
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
K TR2/3/3A TR3 and TR4 Frame Width? Triumph 1
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
O TR2/3/3A TR3 Frame Repair Triumph 1
J TR2/3/3A Frame differences in a TR3?? Triumph 17
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
T TR2/3/3A What gauge steel use for TR3 frame? Triumph 3
B TR3 seat frame issue Restoration & Tools 2
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
CJD TR2/3/3A TR3 Hood Frame Triumph 2
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
mgedit TR2/3/3A Body back on Frame [56 TR3] Triumph 11
G TR2/3/3A TR3 Replica With Space Frame Triumph 13
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
M TR2/3/3A Which frame is correct for early TR3 Triumph 18
HealeyDave TR2/3/3A TR3 Frame Source? Triumph 2
PatGalvin TR2/3/3A Tips for fitting tub on TR3 prepared frame Triumph 23
K TR4/4A Further to TR3 Body on a TR4 frame? Triumph 2
mountainman TR2/3/3A Tr3 Top Frame Webbing ? Triumph 20
D TR2/3/3A Frame Question TR3 vs TR3A Triumph 5
luke44 TR2/3/3A TR3 Frame Dimensions Triumph 9
B TR2/3/3A Question about bad welds on frame 57 TR3 Triumph 6
B TR2/3/3A 57 TR3 Still fighting window frame holder oner's Triumph 6
mountainman TR2/3/3A TR3 FRAME PROBLEMS HELP PLEASE Triumph 11
mountainman TR2/3/3A TR3 Windsheild Frame Question Triumph 8
K TR4/4A The TR3 Body on the TR4 Frame .....Again Triumph 4
mountainman TR2/3/3A Refinishing TR3 Frame Triumph 13
K TR4/4A The TR3 body on the TR4 frame? Triumph 9
M TR2/3/3A TR3 Windshield Frame Triumph 2
gsalt57tr3 TR4/4A TR3 on TR4 frame Triumph 5
S TR2/3/3A Tr3 frame about done Triumph 6
S TR2/3/3A shocks on a tr3 frame Triumph 16
S TR2/3/3A Body to frame tr3 Triumph 4
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
V TR4/4A tr3 body on a tr4 frame Triumph 7
