Hi Andy and Geo,
Interesting info about the Beta!
I'd seen the photos before, but hadn't a clue about the source of the grill. What model is that?
The Beta's front bumper looks like a TR4A, rather than TR4. I wonder what the rear bumper looked like.
Besides the grill, to me the most obvious indication it's not a TR3A or B is the size of the gravel guard on the rear fender. It looks huge!
I'm also unclear on some details about the frame. I know it was made "taller" by welding a section along the main rails. I wonder how this was handled at the front, where they rails are doubled up side-by-side, in the engine compartment and at the front shock towers, or how the minor rails and crucifrom were changed, if at all. Do you know if it had the TR4 style front radiator guard, or the TR3 style rail ends at front?
I find it odd that they fussed with reinforcing the frame to this extent and with some significant loss of ground clearance, then went back to the same height rails, as were used on a standard TR3, when they finally got around to building the TR4. Perhaps the engineers wanted to try a stiffer and/or stronger chassis, then decided it wasn't warranted. Besides, there are much easier ways to arrive at a stiffer and stronger TR3/4 chassis!
I believe the Beta had R&P steering, should also have had 0 degree castor setup front suspension, ala TR3A/early TR4 to roughly CT6000. What engine was used? I wonder if there were any other differences inside or in the drive train. If I ever build a replica, I will use the TR4 axle, I'm sure.
By the way, my TR4 is a '62, but it has some parts that are very, very early. I'm not sure why. I suspect the guy I bought it from in turn got them out of another car a buddy of his had, that was heavily modified with a V8 installed, fender flares, flame paint job, etc. Some "too early for my car" items I've noted are the long-neck radiator (TR3 style, but with 7 psi cap), domed glass on the tach & speedo (but not the smaller instruments) and round-backed seats. I know these aren't TR3 seats, too. Found a tag inside one while pulling it apart, labeled "Zest".
I bet if Standard had decided to build the "Beta" as a production car, they would have had success selling it alongside the TR4.
Thanks for the Beta info!
Alan
