mgedit
I'm finally getting close to fitting the body back on the frame. I've been putting off the temptation to ensure that I've got things done that are much easier to accomplish while the two are apart. So exhaust is back on, brake lines and emergency cable are in, fuel line is complete now except for fuel tap, transmission and diff are topped up, starter and generator rebuild, tested, and installed. I still want to replace cooling system hoses and coolant. Assume vacuum lines and fuel line from fuel pump forward can go on fairly easily later. What else should I consider checking/fixing before reassembly? Cheers, Mike
