Hi,
I temporarily put a jack under the rotor (with a wooden block to protect the rotor) and lift the suspension a little up from full droop, while standing on the frame with my own weight (180-185 lbs), reach under to position the shock and start a nut on top. (This doesn't leave a hand free for a beer, however.)
It might have been a little easier because I was installing Konis and am using slightly shorter, competition rated springs. I.e., with different springs and shocks, more compression might be necessary.
I'd usually wait to install the bottom bump stop/brackets when the wheels & tires are reinstalled and car is settled back on the ground, lifting the suspension slightly.
