Front Shocks
zyrtecx
Why would my Austin Healey 3000 B7J have metal plates under the front lever shocks?
The right side has two plates that run the length of the shock and the left side has only one plate on the inside is the shock that causes the shock to tilt outward.
Should I just remove these plates and bolt the shocks to the frame as they should be?
Patrick67BJ8
Can you post photos?
Z
zyrtecx
One photo is the left and the other is the right after the shocks were removed…
Z
zyrtecx
Maybe has something to do with front end alignment? I’ve owned the car since 1976, has been in a garage for 35 years and I’ve never had it aligned… maybe factory?
Healey Nut
Has the car ever been in an accident , does the frame look to have any modifications or major repairs particularly on the front corners .
Only reason I can think of it being done was to somehow align/level the car to make it sit/look straight ?
Keoke
Only reason I can think of it being done was to somehow align/level the car to make it sit/look straight.
Yeah me too-Healey Nut
Z
zyrtecx
As far as I know the vehicle has never been in a collision, the frame looks to be straight and I see no collision damage repair, there was some bondo in both of the rear quarter panels but no other damage… the entire front end and engine compartment, fire wall Is good… those clips under the shocks look a British part. I’m going to clean them up tomorrow and see it they have anu Stamping on them… all the previous owners of the vehicle are deceased, I have the title history of this vehicle and the statement or origin.
The only thing that I found when rebuilding the right side front end was that the bushing, lower link rear was gone and I think was throwing the right side out of alignment. The front wheels were not in line…
Z
zyrtecx
Forget to mention:
right side spacers under the shock were on the outer side
left side spacers under the shock were on the inner side
the shroud is removed at the present time and I have never had a problem with any body panels, doors have the proper spacing and open and close correctly…
Patrick67BJ8
Why not contact the Registrar of the BJ Registry and see what, if any, info he has on it? He’ll need the vin number, etc.
Z
zyrtecx
I’m going to have the shocks rebuilt and I think that I’m going to remove the spacers and install the shocks the correct way but first I’m going to do done measurements if the frame and the shocks and see if everything match’s on both sides… guess that I’d a good place to start as any…
Home-brew alignment job (for whatever reason):
Our BN2 had excessive neg. camber when we got it, and the frame was straight. We installed the Kilmartin adjustable plates. My BJ8 has too much pos. camber for my tastes so I'll install movable plates under the mounting plates (someday).
Be sure to have your alignment checked after your changes; unfortunately, most shops will be baffled by a Healey suspension (you can only easily adjust toe anyway).
vette
It appears someone has tried to make a change to the suspension geometry and wheel alignment, for whatever reason. I think those shims provide a poor base for the secure fastening of the shock to the frame so i would want to remove them. But the necessity of them can easily be ascertained by putting everything together roll the car unto level ground and measure camber at the least. Camber can be measured with enough accuracy by using a straight piece of steel against the wheel rim and a protractor against the steel to read the angle of the steel hence the angle of the wheel. The Healey camber angle is between 1/2* to 1* positive camber which is the wheel leaning out at the top. If the camber is not within those specs then something is wrong with the frame.
Or perhaps the shocks are replacements of the originals and are of a different dimension than stock--hence the shims.
Are there any markings on the shocks that would permit comparison?
nevets
The fact that they are "U" shaped suggests to me that they are shims slid into place with the shock bolts loosened, as others have already stated, to compensate for some alignment issue. It should be revealing to see how the car handles /tracks with the shims removed vs how it currently drives.
BoyRacer
Back in the day, racers used shims on the 2 outside shock bolts to tilt the shock and eliminate some of the positive camber. But what I see in your photos is just bizarre.
P TR6 New front shocks & air in clutch Triumph 15
A Front Shocks Bushing Replacement Austin Healey 2
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
M Replacing front shocks, torque setting? Spridgets 2
B Front Shocks Austin Healey 6
RJS TR4/4A Replacement Front Shocks Triumph 4
D front shocks 100 m Austin Healey 12
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
N Hillman Imp front shocks wanted Other British Cars 2
tomshobby front shocks, about time I think. Triumph 6
J Front shocks Austin Healey 5
PAUL161 T-Series TF Front Shocks-[Backwards]? MG 5
J Replacing front shocks. Austin Healey 3
AUSMHLY Front shocks: guaranteed not to leak ? Austin Healey 6
R Bugeye front shocks Spridgets 3
mrsprite front lever shocks for sale Spridgets 2
BOBBYR BJ8 FRONT SHOCKS Austin Healey 10
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S BJ8 Shocks and Front End Austin Healey 15
19_again front shocks filler location MG 4
Shinsen774 Install Front Lever Shocks-What's the secret? MG 3
F TR2/3/3A TR3A front shocks Triumph 2
bluemiata90 TR6 TR-6 front shocks in a TR3?? Triumph 2
B front shocks MG 33
zimmy changing front lever arm shocks Spridgets 4
Morris New Front Shocks! Spridgets 2
kodanja TR6 TR6 FRONT SHOCKS? Triumph 24
D Front Shocks. Spridgets 19
mrv8q TR2/3/3A TR3 Front shocks Triumph 4
jscott TR2/3/3A TR3A front shocks Triumph 1
M Front shocks MG 8
M Front shocks MG 4
Basil Front shocks installed tonight! Jaguar 12
Z 3000 Front Wheel Bearings Austin Healey 3
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Z Front Springs Removal Austin Healey 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
crispy BJ8 Front Suspension Austin Healey 9
B Bent frame rails near BE front end Spridgets 2
K TR2/3/3A Front Hub and Felt Seal Triumph 1
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
F TR2/3/3A front body mounts Triumph 7
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
