TR6 TR 6 clutch master rebuild
SteveT
I have tried to search for the name of the company that rebuild's clutch masters and relines them with a brass bore, but to no avail. Anyone know who this might be and any opinions would be greatly appreciated.
The master is leaking on the inside of the firewall, would it be safer to rebuild the entier unit or just get new rubber pieces and install them. I really only want to do this once.
Thanks all.
Steve
Dayton, Ohio
Brosky
I don't think that they use Brass, but rather Stainless Steel liners. Can anyone confrm that?
BobbyD
No personal experience with White Post but there was a thread on them on the Triumph Mail List last year that had mixed reviews. A couple of others that also do this work are Sierra Speciality https://www.brakecylinder.com/ and Goldline https://www.goldlinebrakes.com/ I was going to have Goldline rebuild my calipers until Ted Schumacher offered up rebuilt ones at an excellent price.
I always like having options :smile:
TR3driver
Great Pumpkin - R.I.P
Depends on the condition of the bore, IMO. If it's smooth, then a rebuild will last as well as anything. But if it's visibly worn or pitted, then it should be replaced.
However, I suspect you'll find that a new MC is cheaper than having your old one sleeved and rebuilt.
JPeter
Member
I just sent a master cylinder off to be sleeved to Karps - karpspbresleeve.com
The guys on the Alfa Romeo chat site all use him and swear by his work.
DNK
Yea,but when the brake squeak it will be in Italian.
R_Lyle
Member
Why don't you just buy the rubber rebuild kit? It only costs about $15 and it is very simple to do. Mine was leaking in the same place a couple of years ago so I rebuilt it and now it is fine. Keep in mind that you will want to put some paper towels under the master cylinder in the engine compartment before you remove the hydraulic line. You don't want to mess up the paint. The hardest part of the rebuild is removing the master cylinder from the car.
vettedog72
If you don't mind running the risk of having the fluid run down on the carpet or filer wall and if the bore is not pitted then you can make a good and inexpensive repair. Otherwise, send it to White Post and expect to pay, including shipping, around $150. You might want to ask them to provide a new resevoir and cap that will actually seal up.
By the way, the clutch master is not any better. Check it carefully, it may be leaking too.
S
SteveT
Thanks for all the advice. I think I'll put the rubber pieces in and see what happens. The car has 30K original miles and is a true survivor, and I want to keep as many components as original as possible. Like the alternator that I had rebuilt for $59.00 from a great and unbelievable guy in Dayton, OH. He grew up on Lucas electrical.
Steve T.
Dayton, OH
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
RickB Should I rebuild or replace - clutch master? Spridgets 4
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
N Clutch Master cylinder, rebuild or not. Triumph 26
G clutch master cylinder rebuild. Spridgets 0
kbash T-Series Master Clutch Cyl. Rebuild Kit MG 3
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch Master Cylinders? Triumph 1
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
N TR4/4A clutch master TR4A Triumph 6
sparkydave 1500 clutch master Spridgets 4
drooartz MGB Difference in clutch master cylinders? MG 4
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
tahoe healey Clutch master cyl. push rod Austin Healey 2
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
RickB New clutch master - the expected bleeding nightmare has arrived Spridgets 16
Lukens More clutch / brake master cylinder questions. Triumph 7
Lukens Clutch master problems Triumph 23
Jim_Gruber Clutch Master Rebuilds Spridgets 10
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
sail TR4/4A 4A Pipe from Clutch Master to Hose Triumph 4
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
C TR4/4A missing TR4a Clutch master fitting Triumph 9
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
