Deleted member 23900
Hi folks, newb here. Restoring a 1965 Sunbeam Alpine from a 38 year slumber. Has a Lockheed tin can clutch master cylinder. I've installed the rebuild kit but cant get it to pump any fluid. Not sure if the spring is backwards, how fluid would even push through with the rubber plunger installed as it came out. Completely stumped on something that should be very simple. Does anyone have a schematic or photographic that shows the exact order of how this thing goes back together?
Thanks!
Thanks!
