I replaced clutch master and slave cylinders at the end of April. 1500 miles later, the master is leaking again. I am using DOT5 fluid , but apparently many of you do without problems. This part is from TRF, but
I had a wheel brake cylinder fail out of the box from Moss. Does anyone have a source for better parts?
I still have the Girling master I removed. Would I have better results by rebuilding this? I enjoy working on the car, but am not enjoying redoing my work. Any suggestions? Thanks
