TR2/3/3A torque of the large pulley bolt
sp53
I liberated the idea of a tail shaft holder from one of Randall pictures and it came in handy for torqueing the front pulley big bolt by holding the tail shaft, but I cannot find a spec for the torque of the large pulley bolt?
TR3driver
Great Pumpkin - R.I.P
I've never seen a factory spec for that bolt. However, the threads are 5/8-18, and the standard torque for a Grade 3 5/8-18 is 140 ftlb. That should be enough.
Geo Hahn
In addition to 'tight enough' -- if you plan to retain the hand crank option then you will want the dog to end up in a specific position for ideal cranking. Without looking, I'm thinking 'ten til four' was the prescribed orientation. That position is achieved through some combination of shims and tightening.
S
sp53
Thanks guys I will do about 140 then, so that is what those shims are for I never would have guessed.
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
Drone Dog torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
KVH General TR Torque for the Camshaft Bolts Triumph 3
R Cam gear nut correct torque Austin Healey 2
KVH General Tech Torque Question Triumph 5
B High Torque Starter Spridgets 7
C Need Help Finding Torque Specs for Engine Austin Healey 1
C Drive/Propshaft Bolt Torque Spec? Austin Healey 8
I Off Topic Bolt torque specs Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
B Spitfire Torque specs on rear spring bolt, Spitfire Mk3 Triumph 2
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
S Bell housing to gearbox - torque spec? Austin Healey 4
