TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"?
karls59tr
I can't find this in the manuals. Does each bolt type have it's own torque value depending on size or is the torque always specific to the application?
Karl
TR3driver
Great Pumpkin - R.I.P
20 ftlb for the clutch plate; listed in the engine section.
In effect, there is a default torque for every bolt, based on size, thread and material. Application specifications are often only given when there are changes from the default, or if the torque is critical to the application. I've got some tables at home, but not accessible at the moment.
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
T TR4/4A clutch problem on brand new TR4a Triumph 6
N TR4/4A clutch master TR4A Triumph 6
Zimmycobra TR4/4A TR4A Clutch adjustment question Triumph 2
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
K TR4/4A TR4A Clutch Release bearing Triumph 6
TR4A_IRS TR4/4A Question about TR4A Clutch line fitting specifications Triumph 1
T TR4/4A Anyone have a spare TR4a clutch pedal? Triumph 3
M TR4/4A 67 TR4A Clutch Housing Cover Triumph 4
KVH TR4/4A TR4A Clutch Fork and Shaft Triumph 37
C TR4/4A missing TR4a Clutch master fitting Triumph 9
R TR4/4A TR4A Clutch will not disengage Triumph 6
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
RJS TR4/4A TR4A Heavy Clutch Pedal Triumph 2
T TR4/4A TR4A Through 6 Diaphragm Clutch Triumph 12
T TR4/4A Brake/clutch MC box body color on TR4A? Triumph 4
T TR4/4A TR4a clutch recommendations Triumph 8
T TR4/4A TR4A clutch slave cylinder Triumph 9
T TR4/4A ? on TR4A clutch shaft - wear @ push-rod attachment Triumph 6
Stinger TR4/4A TR4A Clutch Question Triumph 7
Stinger TR4/4A TR4A Clutch Return Spring ??? Triumph 1
K TR4/4A TR4A Clutch MC .............. Triumph 2
K TR4/4A TR4A Beck Arnley Clutch Triumph 3
J TR4/4A TR4A clutch hydraulics Triumph 2
K TR4/4A Clutch Replacement on TR4A. need advice Triumph 11
M TR4/4A TR4A Clutch on a TR4 Flywheel Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
