MGC Rear Diff Cover Bolts Torque?
69MGC
What is the amount of torque for the bolts on the rear differential cover?
Thanks
Kev
Mickey Richaud
Hmmm.... I have a list of torque settings, but for some reason that one's not on there. If I were to hazard a guess, I'd say no more than 8-10 lbs., similar to oil pan bolts.
Mickey
Platinum
I'll second Brer Mick's suggestion. With a thin film of Hylomar or copper RTV it should be good to go.
JPSmit
I'm going with "tight" on this one
Mickey Richaud
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
wangdango '67 XKE rear diff? Jaguar 2
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P rear diff crownwheel help Triumph 3
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
D Spitfire spitfire diff and rear spring Triumph 9
M Rear diff. bearing ID Spridgets 2
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
H IRS diff rear mounting bracket Triumph 0
J 100 rear diff - nut torque Austin Healey 4
Dudly Rear Diff Oil Triumph 11
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
N Rear Diff mounts upgraded Triumph 2
VelodromeRacer Rear Diff oil suggestions? Racing 7
D TR4/4A TR4 rear diff pinion seal Triumph 4
W used rear diff Triumph 2
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
