Petrol Cap Repair?
kodanja
Is there anything that can be done to fix the crack? /bcforum/images/%%GRAEMLIN_URL%%/nopity.gif
short of purchasing a new cap.. /bcforum/images/%%GRAEMLIN_URL%%/troll.gif
Brosky
Bill,
I'm almost positive that one of the big 3 sells seals for these.
RomanH
Looks like you need to replace the seal. There is this guy on Ebay that has them. NFI
Gas cap seal
Looked through my catalogs and the big 3 don't have this item.
kodanja
kodanja
thanx guys
guzzul
If you're looking for the rubber seal on the cap, TRF sells them for $9.95. Part number is 725220. Same as for Spitfire.
I don't have a TR parts manual so I'm not sure about the bottom (filler neck) seal bumper.
AUSMHLY Need photo of an original BJ8 petrol cap Austin Healey 1
T General Tech Petrol delivery Triumph 7
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
F Petrol Drains Austin Healey 11
tr6nitjulius General TR Petrol Prices & BC 94 octane Triumph 7
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Lukens TR2/3/3A Petrol pipe connection to tank. Triumph 9
J Petrol Drain / Intake Manifold Issue Austin Healey 2
Morris Bit OT: dangers of petrol Spridgets 8
Tinkerman TR2/3/3A Petrol Stop TR-3 A Post 60000 Models Triumph 2
AUSMHLY Ethanol in Petrol Austin Healey 3
Tinkerman TR2/3/3A Petrol Level Sensing Unit Ground Wire TR3A Triumph 3
JAV Al petrol tank issue Austin Healey 10
angelfj1 petrol and vacuum line support Triumph 11
Tinkerman TR2/3/3A Petrol Tank Parts NEEDED TR3 Triumph 2
Tinkerman TR2/3/3A Petrol Tank Installation TR 3A Triumph 12
Tinkerman Petrol Stop Tap on post 60000 TR # Triumph 26
2wrench Intrigued by Petrol Injection engines. Triumph 30
angelfj1 TR2/3/3A 3A Petrol Tank Sealer - Is this necessary Triumph 8
B Unleaded petrol in the USA? MG 5
ronzet Petrol Tank cleaning. MG 18
NutmegCT petrol stop tap Triumph 5
W What grade of gas/petrol ?? MG 17
YankeeTR Wedge TR7 Petrol Injection system... Triumph 7
michalotti_tr Lucas Petrol Injection Triumph 24
S World Gas [Petrol] prices? Triumph 27
Gerdo New to the forum and no petrol Triumph 12
C T-Series MG TD petrol pump MG 4
coryandtrevor Z/S carb leaking copious amounts of petrol Triumph 4
coryandtrevor carb leaking petrol Spridgets 2
trrdster2000 Petrol tank mistake Triumph 1
huck6 Petrol Question British Motor Corp 3
mctriumph TR2/3/3A Hub cap emblems Triumph 2
L T-Series Gear box servicing cap. MG 5
C MGB New plug wires and distributor cap MG 10
F Wanted Dipping switch cap Triumph Classifieds 1
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
Overdrive45 Trim Under Convertible Cap Austin Healey 11
E TR6 Strange Steering Rack Cap Triumph 3
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
P MGB Mgb gas tank cap MG 7
A TR6 TR6 Distributor cap issue Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
M TR6 Center cap for wheels Triumph 2
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
