yon_pie_eater said:
Austin's Schedule of Repair times states that to remove the gearbox from the car, dimantle, examine, fit new parts as necessary, rebuild and replace in the car is just less than 10hours. I wondered if the experts out there agree with these times, and if so then I'll try to negotiate a fixed fee with the classic car fitters in my area (hourly rates are very expensive around here...)
Thanks
Andy
Hello Andy,
Here's the situation your in. The only way you can expect a qualified Healey transmission mechanic to do what the Austin's Schedule of Repair times states as less than 10 hours, is if you have ALL NOS parts, sitting on the bench, ready to go in.
Ask me how I know this. After market parts do not always fit. They look perfect, but the tolerances will be off enough, to say, it doesn't work with the other parts. Or the after market part will introduce another problem. Like it fixed this problem, but now it created another problem because it's not matting well with this...
The mechanic will end up doing a lot of trouble shooting.
He would not have to, if he was opening up an unmolested transmission. He would pull out the original old and replace with NOS.
But that doesn't happen any more. Now it's a lot of trouble shooting, trying to get the reproduced parts to work with each other.
I am working side by side with my mechanic. A fixed fee would not be a logical way to go. How does the mechanic know without looking inside what needs to be replaced? How many times must he take out the reproduced parts, you ordered, because they don't fit like NOS would. You find that a used part works better than the new reproduced part you thought would solve the problem. The hours can start adding up.
Best of luck with the rebuild.
