ChrisS
I just thought I would post a couple pics of the front spring hanger I made to lower the rear of the car. I cut the basic "U" shape of the plate out with a cutting disk / angle grinder. The channel is made up of three pieces of 2" wide flat stock. I bolted the plate in place and positioned the channel in the car before tack welding it up; since the rear bulkhead is angle back I took the lazy approach to figuring that out. Now I can fine tune the height with 1/4" and 1/2" aluminum plate under the axle instead of a thicker piece.
