help-extracting [front] leaf spring pins
bighly
TIA.
Has anyone devised a way or found the proper tool for "pushing" removing the rear leaf spring forward pin/bolt. I have been soaking these with WD40 for days and tapping tapping tapping with no avail.
I have picked up a gear puller that may get these loose tonight as well as a C clamp and spacer as plan B.
These are just not budging. I have had some tell me to heat the heck out of it then quench with water.
uurrrrgh
Trying to get this project done so I can attend the California Autumn Classic on the 19-20th in San Juan Bautista.
Cheers
Scott Brunkhurst
I gather the bolt spins in the spring but not in the bushing. The only suggestion I can make is to try "Kroil" in stead of "WD40". Heat the bolt as best possible, not red hot, and cool with water. "Kroil" is the best rust breaker I've found.
SB
Ed Kaler
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Scott Brunkhurst:
<snip> The only suggestion I can make is to try "Kroil" in stead of "WD40". <snip> "Kroil" is the best rust breaker I've found.
SB
<hr></blockquote>
"Busty" is better but N/A in CA. Next is PB Blaster. WD-40 is the WORST.
Also, after soaking ALWAYS try a tighten direction first.
Then more soaking, then undo.
And continue with "do", soak,
"un-do" soak until free. PITA, I know. I have only lost ONE battle in a VERY long time that way.
Good Luck!!
Ed
bighly
bighly
HA. Last resort. I cut the
things off.
Another 10 hour marathon to remove 2 bolts.
Of course followed by the requsite 6 pack of dark ale.
Tonight I reassemble with new springs, shocks etc.
Will I make the CA Autumn classic? heheheheh
Cheers
BN2-NFS
I recently had the pleasure of replacing the rear springs on my BN2. The forward lynchpins were of course frozen and took considerable time to remove. A coupe of suggestions:
First, use your lead hammer (for your knockoffs) as the hammer for striking your lynchpin. I know you have limited swing, so the weight of the hammer is important.
Second, you will need 2 small punches, 1 about 1-1/2 inch long and the other about 3 inches long, so you can drive the bolt through once it is flushed the back.
Also try driving the tip of a large screwdriver between the head of the pin and the mounting--this may partially extract the pin and allow you to grasp the head with vice grips, etc. Wiggle and hit the pin with the lead hammer.
Worked for me!
BN2-NFS
Worked for me!
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
