TR2/3/3A Control Head Video
GerryL
Does anyone know how I can obtain a copy of a video explaining how to repair the control head. I believe this was created on a VHS tape created during a technical session at a national VTR meet.
Gerry
CJD
VHS? I don't think I even have a VHS player any more. Sorry, I have never seen the video, but it would be nice.
RC64
Gerry...
I haven't seen a video but I found a Word DOC file (someone here in this forum pointed it out to me) that was quite useful when I rebuilt my control head. Do a google search for this title and you you'll see a link to the file.
Sidescreen Control Head-disassemble.doc
When you break yours down make sure you note the orientation of all of the small parts in the head. There are two short metal pieces with a beveled end (don't know what they're called) that need to go back in with the right way. If they are not right, the turn signal lever function won't work right. I'm sure you can figure out how I know that. Taking it all back a part is a pain.
Rick...
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
C TR2/3/3A Control Head Rebuild Help Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
C TR2/3/3A Control Head wiring Triumph 18
trotti Control head / trafficator questions Austin Healey 14
B Stator/Traficator [Control Head] Question Austin Healey 2
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
B Another wiring question 57 smallmouth control head Triumph 2
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
Gordon_Dedrick Control Head Screws Triumph 5
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
AweMan Control head question Triumph 4
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
J TR2/3/3A TR3 control head internal pictures? Triumph 11
