The indicator stalk fell out of my control head ('59 TR3) so I decided to dive into the mythical world of the control head and took it apart this weekend. Everything was working prior to dis-assembly, it was simply the screw that secures the lever that came out. Everything came apart well and I just had a few questions before putting everything back together.
1. The grub screws that hold the head onto the steering wheel were all stripped. Moss offers new screws. Are those the best for replacement or is there a better option?
2. I assume I can re-use the nut that holds the stator tube onto the steering box but assume I should replace the compression sleeve (is this the olive?). Is that right?
3. I thought I might as well replace the steering box fluid while I have some of the oil drained out. Is the Penrite oil that Moss sells my best bet for this?
4. As I mentioned above, everything worked fine, but the wires are in pretty rough shape and of course most of the sheathing from the wires is gone. Should I order a new wire set from Moss and pull it through the stator tube or just leave the wires that are currently there.
Anything else I am missing or not thinking about while I have this whole thing apart? Thanks for the help.
