The wiring diagram shows 5 wires off the control head, and of course there are only 4, the 5th one being ground (black). Does the control head ground itself to the steering column when tightened up with the grub screws? Or is there some separate ground wire I need to make? If so, where does it start and where does it ground to?
I checked lots of threads on the control head, but none address the ground question. Thanks in advance,
