carb heat shield
Lin
Hi folks,
Is the carb heat shield for the dual carbs on a BT7 the same as that found on a BJ8, but with 2" holes? Other differences? Insulation panel the same?
Thanks,
Lin Rose
1960 BT7 in restoration
1959 Bugeye
Keoke
No Lin, they are not the same.---Fwiw---Keoke
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
19_again Carb heat shield MG 7
M SU Carb Heat Shield Triumph 6
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Steve P. '78 Midget carb heat shield? Spridgets 1
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
jerrybny Carb Heat Shield Triumph 5
M Heat-related carb issue on BN1 Austin Healey 7
M Better carb heat shields to deal with vapor lock? Spridgets 18
J are the carb heat shields worth it? Triumph 29
Musicman A Question About Carb Heat Shields Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
