TR2/3/3A Setting the SU carb jet again.......
CJD
I just install the jet…didn’t know you could control the height. Using the supplied seals mine comes out just above the base of the Venturi with the choke stowed. The base of the needle must be set, though, it should be flush with the base of the piston.
charleyf
I agree with the above regarding both the jet and the needle. The height of the jet is controlled by the adjustment nut. Once you get the carb put together. You adjust the height by turning the adjusting nut the 12 flats. That lowers the jet to the starting height.
Charley
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
steveg Carb float setting tool Austin Healey 11
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
I Setting up / Tuning an HD6 Carb Austin Healey 3
ronzet Initial Carb setting.. twin SUs BN4 Austin Healey 7
B TR4/4A Some Help with Setting Distributor Triumph 47
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
R Question on establishing a baseline timing setting Triumph 3
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
C Setting bonnet height at front? Austin Healey 8
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
rlich8 TR4/4A A baseline setting on TR4A carbs? Triumph 2
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
