Carb heat shield
19_again
Hi folks, been away a while. Long story. Anyhoo, I need to replace my B's wrist pin bearings and that brings my "might as well list" right to the surface. I have searched the archives and can't find the info, but I recall posts previously about a young guy who had fabricated great carb heat shields, can someone steer me towards him?
Thanks, Mike
Just glad you're back!
...I been thinkin' I'd like one of those too. Not sure where to find one so will keep an eye on this thread.
Wrist pins? You're right down in th' piddly bits!
19_again
19_again
Yup. Had a noise that only I could hear (you know me, the MG Whisperer) so I waited until the smart half could hear it too. Brought it to an unnamed garage who drove it and put it up on the lift but determined it to be sheet metal, in fact told me "Don't worry about it, just drive it". Got louder and brought it to a shop that advertises in our local car club mag. Young guy drove it about 3 minutes and said "bearing". Sure enough pull plug #4 and rattle stops. They gave me a worst case of $3K labor, but I would get back a blueprinted machined engine. Called my buddy that owned a rebuilding business for years and he said I could do it myself and he'd be happy to offer spiritual guidance.
So to your point.... ayuh I'm so far beyond my capabilities that it makes me giggle. But as I've learned from youse guys here, help is just a keypad away. Just got the GT6 frame back from blasting and priming, so once the B's put to bed I get back to the GT.
Good to hear from you, Doc.
:wink:
All this stuff is basic physics. Some tools are part of th' equation but a hammer and some drifts can work in a pinch!!! :jester:
...you can CALL me, Mike!!!
Well I vote for the replacment heatshield, I gewt mine form Gordon at the B hive, but I think it;s the same unit Moss and other sell, I'm assumming you are still running twin SUs, I use a fair amount fo them in my SU carb rebuilding, they are nicely gold cad plated with new insulation pads on them, IMHO, not worth trying to refurbish an old worn out , most seem to crack around the carb mounting holes anyway over time.
May need to call Gordon. DCOE seems to be ethanol fouled to the point it'll need boiling out to clear it. The SU's are sittin' here starin' me in th' face. :wink:
19_again
19_again
Doc, I've seen your garage. Your SU's ain't all that's staring you in the face, time to get rid of that dang 1998 calender while yer at it. Once I get done seeing what the damage is, I'll be able to see whether I will replace my shield or not, if I do I'll take Hap's advise and call Gordon also.
mehheh... that calendar is now UPDATED to a 2008 one! :smirk:
..and th' Elan is no longer BURIED. :laugh:
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
M SU Carb Heat Shield Triumph 6
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Steve P. '78 Midget carb heat shield? Spridgets 1
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
jerrybny Carb Heat Shield Triumph 5
Lin carb heat shield Austin Healey 1
M Heat-related carb issue on BN1 Austin Healey 7
M Better carb heat shields to deal with vapor lock? Spridgets 18
J are the carb heat shields worth it? Triumph 29
Musicman A Question About Carb Heat Shields Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 3
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 42
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 6
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
drooartz MGB Troubleshooting Mikune carb MG 33
T TR6 TR6 Carb Gasket Sealing Triumph 1
HealeyPassion AH Carb Access panel Austin Healey 24
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
Michael Oritt SU H6 carb question Austin Healey 5
T TR6 Carb. Float Chamber Fix Triumph 5
Editor_Reid H6 Carb Mounting Austin Healey 4
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
K TR2/3/3A S U Carb Chambers and Pistons Triumph 1
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 0
