Results 1 to 4 of 4
Thread: rubber seal go towards the inside of the trunk
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,254
    Thanks Thanks Given
    Thanks Thanks Received
    27
    Thanked in
    Does the drip edge or overhang of the rubber seal go towards the inside of the trunk on a pre-60K or does the edge point out? I remember the debate and that someone had the gas tank out and actually looked inside with a flashlight and found the seal was better with the overhang end pointing inside the trunk which sounds counterintuitive; what way was it?
    steve
  2. #2
    Join Date
    Nov 2014
    Location
    Biggsville,IL
    Posts
    84
    Blog Entries
    1
    Thanks Thanks Given
    3
    Thanked in
    Re: rubber seal go towards the inside of the trunk
    I am the one who crawled inside in 2-2-2015 and tried gasket both ways . lip inward vs outward. Like no fit if outward. After much cutting and fitting the height of the mounting flange I, gained an inward fit. I have the measurements and solution on file. Now, 4 years later, I tried the $1 bill test. I have only one section that needs adjustment. should have tested my work 4 yrs ago!! Any one with gasket lip outward, please try the refrigerator test. I would like to know if either way works equally. I have a '60 tr3a TS75773. can make copy of my notes. LeT
  3. #3
    Jedi Hopeful ckeithjordan's Avatar
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    144
    Thanks Thanks Given
    6
    Thanked in
    Keith
    1957 TR3 TS20447LO (2017-)
    1962 TR3B TCF1183L (1979-1982)
    1966 Spitfire MKII (1972-1975)
  4. #4
    Luke Skywalker mrv8q's Avatar
    Join Date
    Jan 2005
    Location
    Los Angeles, CA USA
    Posts
    1,758
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    I’ll play along... I replaced the original trunk weatherstripping a couple of years ago, using the TRF seal, pre 60K car. Using the original as a template, the seal “points” outward. After a couple of years, the top seal now points inward to the trunk, I’m guessing the trunk has naturally forced the seal this way.
    The sides and bottom of the seal remain pointing outward. In my car, the seal was cut in 2 pieces: across the top was one piece, the sides and bottom were all one piece.
    The TRF seal works fine in my experience, and fit perfectly in the channel.
    Best, Kevin Browne
    '59 TR3A #TS58370L
    Look for Ancient Aliens on The History Channel
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
