Hi Lin,
Just another other bit of advice that you likely already know. When you install the seal, compress it into the corners. Make sure that it isn't stretched anywhere. If your particular model has hinge attachments in the seal area, you may have to cut holes in the seal to go around any bolt heads. The thin portion of the seal goes inboard to clear the inner shroud lip.
