TR2/3/3A TR-3A Trunk Rubber Seal
Arrow
I have purchased a new rubber seal that seals the trunk lid. Would someone be kind enough to send a photo of correct install? coinsunc1@aol.com It can obviously only go on one way. Option 1-With the lip folding inward to the trunk opening or Option 2-with the lip folding away from the trunk opening. I believe but am not sure it should fold inward toward the trunk opening. Thanks in adavance for your help. Tom
mgedit
I would be interested in seeing correct install as well. Maybe any pictures could be posted to forum. Cheers, Mike
Moseso
Both the boot lid and spare tire lid rubbers are installed with the lip pointing inwards -- towards the center of the boot and the spare tire opening.
A
Arrow
Thanks! Installed trunk seal lip inward. Still not certain I get the spare tire seal. Would you be kind enough to send or post a photo?
CJD
Oops, mine came outward, so that's how I put it back...
Don Elliott
Mike - For your small-mouth TR3, you will have different seals for the boot lid than the ones shown in the photos above. My "early" 1958 TR3A and all TR2's, TR3s and TR3As up to TS 59999 have a seal thet fits down into a slot. These early cars also has square corners for the seals. Mine came new with one piece straight along the top (just below the fuel filler cap and the rest was a single separate piece that went down one side, across the bottom and up the other side to join with the one across the top. It was held into the slot with contact cement but since I did my restorsation in 1990, the new seals are not glued into place, They stay where they should down into the slots.
As an added point, the length of seal across the top has shrunk about 1/4" and the upper corners may not be as hermetic as they should be. But then, I rarely drive my TR in the rain. This top seal piece is down in the slot and the seal lip is facing towards the rear of the TR. But I can't say if this is correct or not, but I still have the original bits from when the TR was new and I wouldn't have knowingly reversed it.
The seal lip for the other piece is facing outwards on each side and, naturally still as one piece the lip extends outwards at the bottom towards the rear of the TR. On the RHS, this lip half covers the slotted hole for the boot lid stick.
mallard
What Don said above about the two pieces for the the trunk seal was something I did not know. It does make sense though. While trial fitting my deck lid to the 56 TR3 the top part of the seal was to thick, and would not let the lid close. Don if you see this did you trim some off the bottom of the seal?
vivdownunder
Repro early trunk lid seals supplied in strip form are difficult to fit neatly at the corners. If just bent around the tight corners, lip out, the lip sits too high at the bottom and the lid won't close right down. I've had to trim a bit off the lip at the bottom corners with a craft knife. Next time I tried mitred joins which was a lot neater.
I've also had to cut some off the bottom of the seal, which is a tedious job. I ended up running around it with scissors, as the underside isn't seen once glued in. I like to glue the seal down with a silicone bead, then close the trunk lid so the seal finds its ideal level in the channel.
Cutting a single piece to go across the top like Don's car had originally, lip facing into the trunk, provides better water sealing around the upper hinge bolts. I always cut the surplus thread off the upper bolts. If the cut end offends, the threads can be turned around in the hinge.
Trunk seals are a much easier job on the later cars with just a turned up edge around the trunk for the seal and radiused corners.
Viv.
CJD
So, 7 years down the road I have seen both styles. The above is for the post 60k. Here is the "pre":
Note: You will note I did not glue the upper corners (actually they pulled apart after gluing). After a lot of input and study, I realized that water will not flow uphill! So as shown works fine. I never re-glued.
sp53
Interesting John, you did the tr2 Don Elliot style. I gots to say it looks right. I put mine in the channel one piece and not cut to length and did not glue it yet because I figured it might shrink. Now that I see that photo, I am going pull it and copycat. Don had great stuff to share!
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
M TR4/4A Trunk/Boot rubber seal. Triumph 8
H TR4/4A tr4a rubber trunk seal Triumph 8
bighealeysource Rubber trunk seal for BT7 Austin Healey 6
B Trunk Lid Rubber Austin Healey 8
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
R TR2/3/3A Trunk floor replacment Triumph 4
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
S TR2/3/3A tr3 trunk primer Triumph 2
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
S TR2/3/3A T handle trunk lock Triumph 14
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
