Source for rubber door seal material?
NutmegCT
I'm asking several forums about this for my 1960 M-B.
Are there suppliers of replacement rubber (foam) weather stripping? Such as the seal between the trunk lid and body.
I've found a specific (and very pricey) retailer in Germany for the car itself. But I wondered if there are "generic" seal manufacturers in the USA, where I can send the specs and see if they have the material.
Here's a sample of what I need to replace (about 16 linear feet):
And a profile:
Thanks.
Tom
JPSmit
MacGregor in Canada might be able to help. He has a lot of stuff.
NutmegCT
NutmegCT
Thanks gents. I've contacted all three. Also McMasters.
Moss, TRF, VB provide seals. I wonder where they get theirs?
Tom
Gliderman8
Here's another possible source... I've purchased from them in the past and they are good to deal with.
While they may not have what you are looking for, they may point you in the right direction. In any case it's a good source to have:
https://www.bresco.com/
LarryK
Have you tried J. C. Witney? The have a wide source of weather stripping for older cars, and have the drawings to help you find something close to what you need.
Jim_Gruber
Alan Fisher has a roll of what he believes is very close. Try him as frogeye@cox.net
PAUL161
Tom
Tom, Sorry to jump in here this late but, I think Moss gets their door seals from MacGregger. I bought a set from them a couple years ago and they were the nearest perfect match to the originals I could find. I met MacGregger and he's one nice fellow, very dedicated to the originality look and quality in his products.
What ever you do, DO NOT buy door seals from Vic Brit! They are the biggest piece of crap on the market! JC Whitney is just as bad! Really junk! JMHO. PJ
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
R Source for rubber parts Austin Healey 1
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
NutmegCT rubber sidecurtain seal source? Triumph 7
MadRiver Source for rubber bumpers for seats? Triumph 3
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
