tune up time
Chicago
Member
I know if I searched thru archives probably eventually find these ? but it is that time of the year to review these ?s
1970 TR6 pert EI
1.spark plugs. what's everyone using this year? good & bad. Gap? I'm going to try .040 with bosch 4216's Pertronix EI (yes I do keep old points in boot just in case).
2.Timing seems like just about 20 BTDC seems to be happy place. I time with both advance & retard connected. I know some disconnect, why?
3. Using Valvoline 10W30 this year from 20W50 seem to get more reasonable oil pressure, was too high before. now in 70's most of time. Seemed like valvoline had the most of the good stuff per a web article. no it wasn't the valvoline web site : )
4. My strombergs still a little quirky. More rich than I'd like trying ATF in dampers for better response.
5. Choke. book says set with a 5/16 rod between cam and choke to set choke screw. seems too far out for my car. anyone else find this setting off?
6. Using sta lube 85W90 GL4 in gearbox with A O/D this tear seems a little smoother than engine oil. was the only GL4 I could find (Napa)
appreciate any comments on what's working or not working on setups tha year.
piman
Hello Chicago,
Just an answer to one of your questions:- vacuum advance.
The standard ignition setting is quoted without advance and on my 2.5 P.I. engine is 8 degrees before TDC. If the vacuum line is connected, at idle this will advance the timing so if you then set it to the book figure you will have the true figure retarded so on full power (i.e. on full throttle and no engine vacuum) you will have the engine retarded from the ideal setting and lose performance. The vacuum advance feature is an economy device to allow leaner running at part throttle (As a lean mixture burns slower).
Incidentally my P.I. (Petrol Injection) engine distributor does not have a vacuum advance mechanism.
Alec
Rick O.
Timing: Seems way too advanced. I have the retard capsule only and I strobe it to 4 BTDC (retard connected) and get excellent performance and economy (27 mpg highway @70).
Gearbox lube: Be careful with the 80W-90 as it can create excessive pressure/low flow in the A O/D hydraulics that can lead to premature wear. I've been running 30W non-detergent for awhile and like it. 30W was the original specification put out by Laycock for the A O/D's. Also, non-detergency is an important feature since you don't want solid contaminants suspended as there is no fine filtration system in the O/D. Don't know if the Stalube GL-4 product has detergents.
Rick O.
Plugs: Use Bosch plats at 0.045 with Pertronix and Lucas gold. Works well.
I'll have try switching from 20W-50 Castrol GTX to a lower viscosity as I too have very high oil pressures. Also looking at oil filters that flow better (currently using Purolator PureOne)such as K&N, Wix, Napa Gold, or Carquest Premium. Castrol makes a fine oil, don't think I'd switch to Valvoline. Checkout https://www.bobistheoilguy.com/ for good info.
Strombergs: Use 10W-30 and like response.
Choke: I think the clearance was spec'd to ensure the cams would be completely off the throttle when the choke is off. I'd focus more on making sure the cam makes contact simultaneously on each carb
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
S TR2/3/3A tune up Triumph 12
4tecdog Stage 2 tune 1293 Spridgets 7
M Tune up / Maintenance question Spridgets 8
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
BritCarFan A/C could use a tune-up, I think Jaguar 6
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
R Electrical tune up Q's Triumph 8
Paul Slice Changed my tune....... Triumph 2
I TR6 69 TR6 tune up tips Triumph 15
Mark_Gibson TR6 Tune Up Tips for TR-6 Triumph 14
B new member 5.7 tune port in a 7 series bmw? Other British Cars 13
Nunyas oooooooo... aaaaaaaahhh... How to Power Tune... MG 11
J Zenith Stromburg 175 carburator tune? Other British Cars 3
Patton Tune up to isolate a Low Power problem Austin Healey 2
X Dyno/tune social Jaguar 4
T Color Tune Restoration & Tools 9
Basil Color Tune Restoration & Tools 7
