TR4/4A I'm Trying to Tune, Again
KVH
You'd think I could do this by now. Forty-four years since my first TR4.
I've got pre-ignition (run on) worse than ever, fast overheating at long idles, jumpy idle speeds (fast, slow, whatever the mood might be), and smell of fuel too strong.
So, I'll check timing again, point gap and all that. But with the overheating, am I too lean on the carbs? I opened the jets 14 flats and balanced the air flow correctly. Wouldn't the jumpy idle mean something is wrong at the carbs?
As usual, thanks in advance for the good help around here.
TR3driver
Great Pumpkin - R.I.P
When you check the timing, look at it what the mark does as you slowly rev the engine up and back down. It should advance smoothly, as a direct result of engine rpm. If it puts on a light show, your distributor needs attention.
Otherwise, it's just the usual detective work. Be assured that, no matter what, the problem will be the last place you look.
KVH
KVH
I think the only change was me fiddling with idle speed and mixture. I have SUs so no such part. I think I set mixture right but maybe not.
sp53
The run on might be carbon build up from running to rich because one of the jets did not return. Or maybe a needle did is not closing on the float and is letting too much fuel in. I am think carburation.
D Trying to get back working on the 1974 Midget Spridgets 11
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
Trevor Jessie Trying out a camera mount... Spridgets 20
M Trying to Find a Family Heirloom Triumph 59
Mark_Barton TR4/4A Trying to replace TR4 transmission mount Triumph 13
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
