Changed my tune.......
Paul Slice
Being a late model MGB owner I was conditioned to hate Zenith Stromberg carbs with a passion. The water choke on the single carb along with the very restrictive manifold design means that most of them end up in the trash can and are replaced with SUs or a Weber carb.
When I bought my 71 TR6 it had been converted to 2 inch SU Carbs from a Jag. With this setup the car would run out of power around 4k RPM and was only getting 12 MPG.
After talking to Jeff at Paltech https://paltech1.com/index.html I decided to go with the origional ZS setup that had been rebuilt and polished by Jeff.
After driving the 6 with the rebuilt ZS's for a couple of weeks I have done the right thing. The engine now pulls strong to the redline yet idles nicely around 800 RPM. The gas mileage is up to the mid 20s which is much improved over the HD8s.
The carbs came allready set up and put together and only required the idle to be set, every thing else was allready adjusted.
I now have newfound respect for the ZS carbs and would recomend Paltech to anyone needing their carbs rebuilt. The finish on then is outstanding inside and out.
Paul
Brosky
I'm hoping to have his tri-carb setup on my TR6 by spring.
Yours and Tinsters look very good.
R6MGS
I've had too many 6's over the years to remember what carbs they had...but this one and my previous 6 had the factory ZS carbs, on my current car both carbs where recently rebuilt before I bought it....and perform very well after I gave them a quick tunning. But I am not so sure about that factory air cleaner...My car seems to run better without it(I removed it to tune the carbs and haven't put it back on yet) it's got a band new filter element, so I think the problem is in the initial design - doesn't look like the caseing allows alot of air in.
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Lin Times have changed - thank goodness! Austin Healey 13
NutmegCT So many cars! So much has changed! Other Cars 10
S TR2/3/3A when the seats changed Triumph 5
DrEntropy Default font size changed? FORUM Navigation Questions 1
H Has anyone changed their electrical distribution? Austin Healey 7
Cookie Has anyone changed wheel cylinders? Spridgets 20
ekamm Changed Plugs, Sooty Triumph 10
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
jcatnite Something changed Spridgets 6
G Torquing rocker pedestal changed clearances Triumph 1
TR4 Should Tranny Oil be changed? Triumph 8
SCguy Wedge TR8 Fluids changed/detailed pictures Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
S TR2/3/3A tune up Triumph 12
4tecdog Stage 2 tune 1293 Spridgets 7
M Tune up / Maintenance question Spridgets 8
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
BritCarFan A/C could use a tune-up, I think Jaguar 6
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
