TR6 TR-6 Tune Up Shop Recommendation
erstearns
While working on Bugeye restoration I noticed my '73 TR6 was looking forlorn and neglected. Have fixed many of the PO boo boo's but cant quite get it to run like I remember (had a '76 many years ago). Old girl can't quite get out of her own way. Carbs rebuilt, new dizzy etc but can't get it tuned to my satisfaction. Have tried fooling with timing (vacuum gauge tried too), sure carbs need tinkering with also. At this point I think I need some more experienced help.
Can anyone recommend a good tuner shop in WV or SW PA (Pittsburg or south)? Don't think there is anyone in north central WV but I would consider anywhere within an hour or two.
Right now all style, no substance. Looks ain't everything.
Can PM me if necessary.
Thanks, Eric
poolboy
73's had some fickle carb's. They were just like the 74-76 except one thing and that was the 1 year only lever that transitioned the float chamber vent.
If you want to troubleshoot that, just repost.
Other than that, I'm no help with your dilemma.
hondo402000
did you send your dizzy off and have it rebuilt? when I first got my 71 TR6 I took the dizzy apart and one of the weights was frozen so I sent it off to be recurved by Jeff at Advanced dist
Hondo
tdskip
She does look great however...
+1 on Distributor health check from Jeff
We can work through carbs here.
What is her timing like now?
big6
From your photo it looks like the rear carburetor vent has a stainless braided hose to the valve cover. The front carburetor has what looks like a black hose going to ???... The stainless braided hose going across the front is used for what purpose?
I graduated from Fairmont State College now University in 1974. At Fairmont State to make some additional money I was in the work-study program and was selected to work in the automotive lab for the automotive instructor at that time Richard Whiteman. Richard was from Bridgeport and back in ’74 ran a Fiat in SCCA events. I serviced Richard’s Fiat, Corvette, and Jeep flat head CJ. I also serviced the machine shop instructor’s MG Magnett and the strength of materials instructor’s Volvo with two Zenith-Stromberg’s with a pointer and harmonic balancer that did not match at TDC. Richard is probably in his early to mid 70’s now and if he is still living in the Bridgeport area and would be an excellent resource.
The vent system on the Zenith-Stromberg carburetors is critical to air/fuel mixture control. I would look at that system first… The distributor bushings will wear but installing a Crane optic ignition will fix that. The springs and flyweights are easily serviced. If you are running the vacuum retard I would change to a vacuum advance unit. I modified the point mounting plate adding a stop for the advance. I also run triple Stromberg’s.
Another thought was University Motors used to be in Pittsburgh PA. I bought a left rear wing for my ‘67 Healey Sprite in ‘71 after being hit by an SS ’66 396 Chevelle. The owner of the Chevelle offered me his car to pay for my injuries and the damages to the Sprite. Probably should have taken the Chevelle…
DougF
Two SW PA shops that come to mind are Boffo Motors in New Brighton, (724)843-3181. Jim has a terrific knowledge of British cars and their workings. McB Motorcar in Bridgeville (412)221-9099 has been around for a long time, but I don't know much about them.
E
erstearns
The black hose on the front carb I believe is a fuel tank vent hose. The hose from the valve cover you have identified, the other is a hose from the brake unit to the intake manifold. There is another stainless hose at the front that is visible but that is a water hose from the thermostat housing to the manifild. Plumbing may not be optimal after removing carbon can etc. Need some help there.
The dizzy was rebuilt and re-curved by Jeff, I believe with only the mechanical advance used.
Carbs were rebuilt by Jeff Palya and have not been touched.
Will get the vacuum gauge back out check and retime, can't recall what it is.
Don't know if cam timing is correct or if harmonic balancer timing marks came back from rebuild correct either.
69tr
There is a shop in Roanoke, Va called Webb Motors. I haven't had any work done there but they seem to be busy. I did buy some wheels from them and they were straight and true just as they said.
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
S TR2/3/3A tune up Triumph 12
4tecdog Stage 2 tune 1293 Spridgets 7
M Tune up / Maintenance question Spridgets 8
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
BritCarFan A/C could use a tune-up, I think Jaguar 6
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
R Electrical tune up Q's Triumph 8
Paul Slice Changed my tune....... Triumph 2
I TR6 69 TR6 tune up tips Triumph 15
Mark_Gibson TR6 Tune Up Tips for TR-6 Triumph 14
B new member 5.7 tune port in a 7 series bmw? Other British Cars 13
Nunyas oooooooo... aaaaaaaahhh... How to Power Tune... MG 11
J Zenith Stromburg 175 carburator tune? Other British Cars 3
Patton Tune up to isolate a Low Power problem Austin Healey 2
C tune up time Triumph 3
X Dyno/tune social Jaguar 4
T Color Tune Restoration & Tools 9
Basil Color Tune Restoration & Tools 7
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
becerrex MGB Car Shop in Salt Lake City MG 10
