TR6 Another novice question re:TR6 tune-ups and chokes
bricktop
So.....took my 6 to the professionals last week for a tune-up. Got all the basics and a carb adjustment. Now I have a before and after situation.....BEFORE taking the car in for service, when I would start the car cold with the choke fully engaged, it would jump up to a 2k RPM idle. As long as I let the car warm up properly before driving off, I could disengage the choke and the idle would stabilize at 900-1000 RPMs and generally remain strong.
AFTER the service, when I start the car cold with the choke fully engaged, the engine will barely maintain 1000 RPMs and the idle is shallow and weak. Even after a ten-minute warmup, the idle remains shallow. In fact, I have to keep the choke engaged at all times for the car to idle AT ALL.
Anything a novice can troubleshoot at home before having to take the car all the way back out to the shop for a fix??
Thanks.
TR3driver
Great Pumpkin - R.I.P
Almost certainly something you can take care of, but I wouldn't want to even try. If you touch it, and then find something is screwed up (eg stripped threads in a carb) the shop will claim any problem is your fault.
I'd take it back to them; and then next time do it yourself. Otherwise, you are going to wind up doing the entire tune-up yourself, since it could be almost anything (and it's all designed to be do-able at home).
poolboy
Aside from the problem getting it to idle,are there any other problems? Will the engine rev up normally ?
The problem could be that the choke cable/fast idle screw is not adjusted properly along with the idle speed (throttle stop) screws.
Tell me more and I might be able to narrow it down.
DNK
And beside that I hear Poolboy does house calls
DaveatMoon
I agree totally with Randall. You pay people for service, and this isn't acceptable. If you so much as turn a screw you've lost your leverage with them to have them fix what they did.
However if they find anything "wrong" that needs repair or replacement, take it somewhere else (assuming you don't want to take it on yourself, which is pretty straightforward with these cars). The last thing I would do is give these guys another opportunity to make money monkeying around with your carbs.
TR3driver
Another possibility might be that they believed the book, where it says to adjust the timing & idle with the vacuum line disconnected. If you set the timing to 4 ATDC with the line disconnected, then hook the vacuum retard back up, it won't idle. Or even setting the timing with the engine a little overheated (so the TVS activates) can cause problems.
poolboy
The thing is, I can't believe these guys let it out of the shop when it wouldn't idle. Or, for that matter, why you left the shop with it running that way.
I'd just hesitate to go back to a shop that was that carefree.
poolboy
Have Vacuum Gauge (and stethoscope)
Will Travel
wire poolboy
Sandy Hook
Brosky
That is a nice gauge Randall.
I would call the shop and tell them that you expect it to run better, not worse when they tune it up. Make an appointment to see the owner when you take it back.
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
D Another use for a leaf blower. Restoration & Tools 1
