Electrical tune up Q's
rooster
Hi,
I'm going to be replacing some of the ingnition components on my 76 TR6, before putting my car back on the road in the spring.
How can I tell if it there is a ballast resistor for the coil?
What are a recommended spark plugs?
How bout spark plug wires? Are the ones from the big 3 any good or should I look for some generic ones locally?
I am also thinking of putting in a pertronix pointless ignition, is there a particular one I should look for or are they all the same?
Thanks
martx-5
I don't have a TR6, so I can't answer most of your questions. However, you can tell if you have an internally ballasted coil or not by measureing the resistance between the two small posts on the coil. Remove at least one of the wires when you do this. If the coil is internally ballasted, it will measure about 3.0-3.5 ohms. If it is externally ballasted, it will measure about half that, or about 1.5-1.6 ohms.
BTW, the wiring diagram for your '76 shows a ballast resistor wire going to the coil.
Brosky
I used Magnecor Competition wires that I got from Moss. No radio interference.
Pertronix ignition has worked well for me. I matched it with their coil. Just give TRF or Moss your year and model and they'll send the right parts.
I like NGK plugs for the TR6.
Wires, dizzy & coil shown below:
R
rooster
Thanks for the tip about measuring the coil. I should get a wiring diagram for my year. I only have the earlier manual, that dosn't cover the later years.
R
rooster
Hi Brosky,
I can get the pertronix and coil from a local place that specialises in electical components for cars. Their price is about 40 bucks cheaper for the pertronix after shipping and duties ect ect. I just need to give them the correct model number. I 'll ask them about the magnecor wires.
Do you remember what type of NGK plugs you are using? Don't bother to go an pull them on my account though.
Thanks!
martx-5
Here ya go. Courtesy of Advance Auto Wire. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Alan_Myers
Hi,
You might search the archives a bit regarding Pertronix. There have been a lot of discussions about them in the past.
NGK get my vote too, just the standard ones... not the multi-electrode or platinum, unobtanium, kryptonite. I don't have a TR6, so can't say exactly which NGK, though.
There are a number of sources of good, uprated plug wires. I've got Magnecor on my Land Rover and I like them. Pricey though. My TR4 has Mallory wires, that seem fine too.
R
rooster
I have Champions, I will pull one and see if there is a
NGK equivalent for it, which there probably will be.
Thanks
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
L Should I do it?? [electrical conversion] Austin Healey 24
SherpaPilot TR6 Electrical Question Triumph 7
