Got_All_4
What a tool! Bought this probably 4 years ago and finally took the time tonight to use it on the TR3. It actually took no time at all. After a carb balance I replaced the # 1 sparking plug with the glass one provided in the kit. Right after start up I could see plain as day the yellow ring of combustion fire. A few adjustments on the SU jet and you can watch the combustion go from too rich to just right. 1/2 hour process at best.
You could hear the changes in the engine as your adjusting the jets. Smother idle and quick response on the throttle. I actually had to bump up the idle a bit to keep it running. The plugs were so sooted up and hope this cures my fowling plug problem. The true test will be driving it. Won't be able to do that till the latter part of the week after i get my tyres installed (Vanderstines) on my newly painted wheels.
If too lean I'll just keep turning the jet nut a 1/4 turn to richen it up until the power comes back.
