used reverse with OD switch on
nevets
I backed out of my garage with the OD switched on. Had just a bit of trouble getting into reverse and heard a few clicks. I drove off and realizing what I had done, I flipped the toggle to Normal while still in 2nd gear. I drove a bit but not far or fast enough to try the OD. My question is, how likely is it that I caused any damage? Thanks
vette
Hi Nev, If the little switch on your transmission shift lever is hooked up and working correctly you probably didn't do any damage. The little switch only allows the OD to be engaged when the trans is in 3rd or 4th gear. So the electricity never got to the OD solenoid. Donald thought about your posibility way back when, remember who they were trying to sell these things to back in the '50s & '60s. Dave.
Keoke
"Hi Nev, If the little switch on your transmission shift lever is hooked up and working correctly you probably didn't do any damage. "
I agree with that--Keoke-:encouragement:
5
57_BN4
Even if your OD was actually on in reverse, you'd have to go quite some distance to build up enough pressure to get the OD clutch fully engaged. Andy.
For your own piece of mind, first chance you have, check the od wiring to see if it is installed properly. You will probably do this again.
Marv
John Turney
I agree with vette and Keoke. Those clicks you heard may have been the OD relay. When my OD would stick on, I had to put it in reverse momentarily to get it to come out until I could get it fixed.
healeyblue
You mean solenoid getting stuck? If all is hooked up properly and the "relay" sticks, it should not matter, as long as you are not in 3rd or 4th.
Patrick67BJ8
I've only seen the OD left ON once, but when the car was put in reverse the solenoid might have been stuck but it made a heck of a noise. It had no pressure from driving but there's something inside that doesn't like reverse pressure or no pressure.
John Turney
I wasn't clear. My OD would stick for mechanical reasons. Even though the solenoid would release as it should the OD wouldn't release. My point was that it didn't hurt being in reverse for a bit.
nevets
nevets
Thanks for the comments. I'm still kicking myself over this. Hopefully no harm was done. The reason why the switch was in the OD position was because several weeks ago I was doing some OD electrical troubleshooting, trying to discover why the OD was not engaging, and I hadn't touched the car since.
TimK
I've had the OD switch on while reversing dozens of times. The gear shift switch protects against engaging the OD unless the shift lever is to the right (3rd/4th). You can check if your gear shift switch is working if the OD does not engage while in second gear with the dash switch on.
pan
If the overdrive wasn't protected by the top-gear switch mentioned above by others, the car would not have moved, only free-wheeled. There is a thing inside the overdrive called a "sprag" or one-way clutch" that prevents drive in reverse. I too recommend checking that the top-gear switch is functional.
5
57_BN4
The sprag is the bit that grenades when reversing in OD. It over-runs when driving in overdrive since the annulus (output) is spinning faster than the planets (input) because the OD clutch has locked the sun stationary. If the sun is still locked stationary in reverse then the power tries to feed through the planetary gears at 1:0.7 ratio at the same time as through the sprag which is now trying to turn in its locking direction at 1:1. This difference of ratios applies a massive overload to the sprag from only mild torque input.
The earlier Borg Warner ODs suffered from exploded sprags a lot more often because they have no clutch, only a peg that drops into a slot to engage OD. If the peg sticks in the slot- as they often do- then kerbang in reverse. The Laycock design requires the clutch to be pushed firmly into the engaged position which is far less likely when backing out of the garage as there is no hydraulic pressure. If the clutch is firmly stuck in OD due to mechanical problems then it will quite likely grenade and the gear lever switch will not prevent this.
Andy.
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
dougie Use your car as it was meant to be used Austin Healey 15
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
tr6nitjulius For Sale TR6 New/Used Parts 4 Sale Triumph Classifieds 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
S TR2/3/3A used POR 15 for like a base primmer Triumph 8
D Used cars/parts Spridgets 6
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
dougie Big Healey Six - Used the Right Way Austin Healey 5
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
C What is this used for? Austin Healey 4
steveg Has anyone used a knock sensor? Austin Healey 0
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
J Pre-War Steering box used in Pre-war? MG 6
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
T MGB My '80 B used to shift fine MG 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
floyd TR6 need of used carpet set Triumph 0
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
RickB Any fiberglass one piece fronts available used or cheap? Spridgets 15
5 I used to own one of those Spridgets 6
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
M Properties of wire used in harness? Spridgets 29
S TR2/3/3A used thermostat Triumph 5
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
Boggsy64 MGB Used or Spare parts? MG 6
MY66AH Has anyone used this paint?? Spridgets 7
W Bought a used center console a while back..... Spridgets 6
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
floyd TR6 used tr6 carpet Triumph 0
J Need used starter post TS50000 Triumph 2
coldplugs Bricklin in a used car lot Spotted 0
Trevor Jessie Looking for used seat covers Spridgets 13
J Source for used front hubs? Triumph 3
PAUL161 What ar these used for? Restoration & Tools 9
