Used cars/parts
David_Doan
Craigslist used to be the go-to for used cars and parts. I live in the Dallas area, there’s now only one sprite/midget listed at all. Where do people list stuff to buy/sell these days? Facebook?
My Bugeye still has a 948, smoothcase, and 4.22 diff. I want to upgrade to 1275, etc. I’m thinking I’d be better off to buy a parts car.
ralphtyrone
you can try Facebook , or Ebay, or the Austin Healey experience, or try the three major Austin Healey clubs web sites, good luck.Ralph>
JPSmit
are you involved with a local club? it's amazing what is squirreled away in people's garages; "I know a guy who knows a guy"
ralphtyrone
I belong to 6 local clubs. here in N.J. I also hold local Cars and Crumpets events 11 times a year . you can check it out at NJBCC.ORG.
Rut
David,
I find a lot of cars and parts on FB Marketplace, but some of the flea market/garage sale sites must be joined.
Good luck,Rut
Scargo
I was in the same boat about 15 years ago with a bog standard Bugeye.
I searched and found a basket case '73 Midget for sale. When I went to look at the car the first thing I did was remove to the plugs and hook up a battery to see if the engine would crank and build oil pressure. Once it did, I hooked up a can of fresh gas and an electric fuel pump, and started it up. It ran with no smoke out the exhaust pipe, and I then ran it thru the gears while up on jack stands.
When I got it home, I stripped it to a bare shell salvaging the 1275, ribcase box, 3.9 diff and front & rear brakes, all of which eventually went into the Bugeye. I had the bare shell hauled off on a rollback for free, and it either went to a junk yard or a metal recycler. I sold off many of the salvaged parts and pieces and actually recouped all of the purchase price plus some. In fact, I have a few boxes of parts remaining which I am still slowly unloading.
This worked well for me, and could very well work for you too. Good luck.
Scargo
And to piggyback on some of the suggestions above, you might also check the classifieds on MG Experience.
T AH Muffler used on other cars Austin Healey 4
G Buy relplica classic cars NEW produced or used Austin Healey 4
Geo Hahn Orval's Used Cars Other Cars 17
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
dougie Use your car as it was meant to be used Austin Healey 15
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
tr6nitjulius For Sale TR6 New/Used Parts 4 Sale Triumph Classifieds 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
S TR2/3/3A used POR 15 for like a base primmer Triumph 8
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
dougie Big Healey Six - Used the Right Way Austin Healey 5
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
C What is this used for? Austin Healey 4
steveg Has anyone used a knock sensor? Austin Healey 0
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
J Pre-War Steering box used in Pre-war? MG 6
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
T MGB My '80 B used to shift fine MG 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
floyd TR6 need of used carpet set Triumph 0
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
RickB Any fiberglass one piece fronts available used or cheap? Spridgets 15
5 I used to own one of those Spridgets 6
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
M Properties of wire used in harness? Spridgets 29
S TR2/3/3A used thermostat Triumph 5
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
Boggsy64 MGB Used or Spare parts? MG 6
MY66AH Has anyone used this paint?? Spridgets 7
nevets used reverse with OD switch on Austin Healey 12
W Bought a used center console a while back..... Spridgets 6
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
floyd TR6 used tr6 carpet Triumph 0
J Need used starter post TS50000 Triumph 2
coldplugs Bricklin in a used car lot Spotted 0
