A/C could use a tune-up, I think
BritCarFan
Hello all,
With the 90 degree weather approaching, I think it's time to do a tune-up on the A/C system. It seems to blow cool but not cold. Anybody got any thoughts on this
healeynut
sounds like it's time for a recharge on the AC coolant. Just take it to your mechanic, should be a quick fix.
maynard
Sounds like the car needs some refrigerant added. As a 93, it could be either R12 or R134. You can tell by the fittings. If they look like tire valves, R12, if they are bigger, without threads on the outside, they are R134. If it is R134, you can try adding a can yourself. If the car has a sight glass, just add R134 until the bubbles disappear. If it is R12, you need a shop to top it off, since R12 can only be sold to a licensed tech.
Exotexs-I have to disagree. If a R134 system is properly designed and operating properly, it is as cold as R12. In my 94 XJS, on a 95 degree day, I get 0 degree F air our of my vents. Last week, on a 91 degree day, my glasses iced (not steamed) up when I left the car.
The problem occurs when a system is converted from R12, Depending on the car, you may need a different expansion valve, orifice tube or H valve. Most shops don't do a complete conversion because of the difficulty (the aluminum fittings often corrode and strip out) or because they can get adequate (not optimum) results without doing it.
Exotexs
Maynard, you said it: "If a R134 system is properly designed and operating properly, it is as cold as R12"
but they never operate properly do they?, especially if it's a conversion. Personally, I don't like R134a, (I won't use it in my cars), in any case I would use an alternative refrigerant like "Freeze12" or others. But R12 is still available, and as long as it is, there's no better, it is the automotive refrigerant to which all others are compared, as you just said: "as cold as R12".
Ex
BritCarFan
BritCarFan
The Jaguar uses the R134 coolant, but it does not have the sight glass. I guess there must be a certain pressure needed in the system.
Platinum
Manifold gauges and refrigerant. You MAY get away with squirting more in the system with one of those "kits", but it'd be best to have someone with a set of gauges check the pressures in case you've a problem within the system.
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
S TR2/3/3A tune up Triumph 12
4tecdog Stage 2 tune 1293 Spridgets 7
M Tune up / Maintenance question Spridgets 8
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
R Electrical tune up Q's Triumph 8
Paul Slice Changed my tune....... Triumph 2
I TR6 69 TR6 tune up tips Triumph 15
Mark_Gibson TR6 Tune Up Tips for TR-6 Triumph 14
B new member 5.7 tune port in a 7 series bmw? Other British Cars 13
Nunyas oooooooo... aaaaaaaahhh... How to Power Tune... MG 11
J Zenith Stromburg 175 carburator tune? Other British Cars 3
Patton Tune up to isolate a Low Power problem Austin Healey 2
C tune up time Triumph 3
X Dyno/tune social Jaguar 4
T Color Tune Restoration & Tools 9
Basil Color Tune Restoration & Tools 7
