wkilleffer
Hey everyone, been awhile since I stopped by.
Anyhow, I'm having some frustration with tuning my MGB. It's a 74 with an 18GK engine and HS carbs and a Flamethrower dizzy and coil. Kind of a bit mongrelized, which could be part of the problem, but it's run better before, and it's not like these engines are rocket science or anything like that.
It's been pretty cool down here in southeast TN, and it just seems like my car runs pretty crappily at outdoor temperatures of 50deg or lower. It's hard to get it tuned where it's not running too rich or too lean, and the cold air seems to keep the engine from reaching full Normal operating temperature.
I've wrapped the oil cooler up, but haven't done anything to the radiator. There's no insulation under the bonnet.
Truth be told, I find the whole tuning process to be an exercise in frustration. I don't know anyone around here right now who could help me out.
I know some of the basics of tuning and balancing the carbs, but no matter what I do, the exhaust seems to have that poppy, irregular sound to it that I've been told isn't correct. Last time I checked the compression back near the end of last year, everything was fine, and I've not driven the car much since then. I check the timing before doing anything to the carbs, and it's where it should be.
So, what am I doing wrong? I'd drive the car a whole lot more even in cold weather if I didn't think I was slowly damaging it or something due to an improper tuning.
Any suggestions would be appreciated.
Thank you,
-Bill
Thank you,
-Bill
