Color Tune
T
triumphant
Has anyone here ever used the "color tune". Its like a spark plug that you can see thru and tell when the mixture is right. You adjust the mixture until the color is just righ. I was wondering if these actually work, or is it just a waste of money?
Larry
Caretaker
Provided your garage is or can be made fairly dark they work a treat, bright sunlight shining on them can make them difficult to see, just takes a bit of practice in reading the flame colour
Dave
T
triumphant
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Caretaker:
Dave
<hr></blockquote>
Thanks for the feedback. Is it fairly precise? I mean, can you really tell when the mixture color is just right, or is there a wide range where it looks similar? I guess what I'm asking is, in your opinion, is it worth the money?
Thanks, Larry
billca
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by triumphant:
Larry
<hr></blockquote>
A few years ago I regularly used the colortune to set the low speed mixture for my +4 Morgan (same engine as Triumph TR3) which I was using for vintage racing. I bought two of them so I could adjust the front and rear carbs simultaneously. They worked well, and I had no trouble distinguishing lean from rich mixtures at idle.
They aren't meant to be the only tool for carb adjusting since they are not designed for balancing multiple carbs or adjusting mixture at higher speeds under load.
I recommend getting one to play with.
Bill C.
Administrator
Boss
I have had the same question myself. I think I will get one to help me tune the Webers on my spitfire. Now the next question, billca, is where can I get one?
A
aerog
Moss sells them as well as quite a few other mail-order places on the web.
A
aerog
By the way - the book "Tuning SU Carbs" (or something like that - Moss sells it) has a section that discusses how to use Color Tune and also how to use it with multiple carbs.
T
triumphant
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by spit6 guy:
hello
when I was surfing the other day I cameto a
page that gave a very good describtion on how to tune your cars with su and zs carbs they said that using the colortune is a great help and also how to use it so if you want to veiw this page here it is.
https://www.vtr.org/maintain/carbs.html
spit6 guy
<hr></blockquote>
Wow, thanks guy! That's a great writeup...very comprehensive! I did notice that the ColorTune is listed in Victoria British parts cataloge too, so I will probably go ahead and but one.
Thanks,
Larry
DougR
The color tune DOES work great, but while you're at it, the "unisyn" synchroniser is an inexpensive essential. I have an old unisyn which differs from the new reproduction tool mainly on the "cushion" side (where it seals against the carb intake). The original style is about 5/8" thick where the repop is like 1/8". Modifying that with added weatherstrip material will make the tool a lot more useful.
Doug
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
Basil Color Tune Restoration & Tools 7
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
T BN7 wiring diagram in color Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
Rut Bugeye generator color Spridgets 22
simon1966 100 X Brace Color? Austin Healey 16
F TR2/3/3A Wheel Color Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
J TR6 Paint color Triumph 22
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
maxwedge5281 engine compartment color Austin Healey 2
R BT7 Brake Drum Color Austin Healey 7
