Tub Almost ready to come off [pics]
Miser
I plan on pulling off the tub this weekend. I am going to wield supports to the inside of the doors and pull off the tub and put it on a dolly then off to the sandblasters!
Brosky
Great job. Keep the before and after pics of the body and frame coming.
hondo402000
sand blast or do you mean Soda blast or media blast,
you sand blast that body and you will warp the crap out of the pannels,
I know cause I warped the trunk deck and had to buy another one
unless you like lots of bondo on the car then sand blast it
Hondo
M
Miser
yes it's Media blast. On another note Can anyone list the points at which the tub is held to the frame. I have taken the ones in the engine bay off but I have no idead where the ohters are.
TR6BILL
TRF sells a body mounting kit that includes new everything for screwing the body down, including many shims. Try to remember where the shims might be and mark down. These bodies often were shimmed for proper fitting.
DougF
Put the shims from each mounting location in a separate bag and mark the bag as to where they came from. It will help when putting things back together. It won't necessarily be the same, but a good starting point.
Darrell_Walker
At the back, there is the tire hold down, and the two ends of the frame.
Inside the passenger area, there are two brackets on each side along the outside rail, each has several bolts.
Toward the center, along the drive shaft tunnel, there is one on each side.
M_Pied_Lourd
Miser
Pics of mine from left to right = rear to front to go along with Darrell's description above
Cheers,
Tush
tdskip
Miser said:
tdskip said:
Good progress.
What are you going to prime the sandblasted body with?
Not sure my paint guy is going to do that. He did my MG also.
Ask! Personally, I'd <span style="text-decoration: underline">insist</span> on an epoxy sealer to make sure no moisture can get to the metal.
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
T TR2/3/3A Body Tub Weight Triumph 8
F TR2/3/3A TR3A tub assembly Triumph 44
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
S TR2/3/3A Bracing the tub for removal fom frame? Triumph 14
S TR2/3/3A steering column through the body tub Triumph 5
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
DornTRoriginal TR2/3/3A Tub gap between Frame Drivers side Triumph 3
S TR2/3/3A tub work and holes Triumph 11
Popeye TR4/4A Best way to transport a bare tub? U-haul utility trailer? Triumph 11
S TR2/3/3A painting the body tub “inside” Triumph 31
S TR2/3/3A body tub welded Triumph 2
B TR4/4A Body tub differences - TR4/4A Triumph 8
C TR2/3/3A Flipping the tub Triumph 9
Hot Wings Title for a tub? Spridgets 9
CJD TR2/3/3A TR2 Tub Triumph 9
B T-Series MG TD Tub MG 5
B T-Series Tub Size MG 2
S engine is back, tub is bare,frame is bare Question Triumph 9
B Question about my 57 body tub Triumph 2
MGTF1250Dave T-Series TF Body Tub MG 3
MGTF1250Dave Nails for T Series Body Tub MG 8
K TR4/4A Bracing the tub for fender and sill removal TR4? Triumph 6
S Body tub shims Triumph 1
J TR2/3/3A TR3 tub weight? Triumph 16
O TR6 TR 6 Body tub Removal Triumph 9
A Material between front fender and tub Triumph 15
G TR2/3/3A Threaded rod to Assist TR3 Tub Placement Triumph 6
PatGalvin TR2/3/3A Fitting tub on frame - 59 TR3A Triumph 8
S TR2/3/3A tr3 tub shims Triumph 2
Twosheds TR2/3/3A TR3 Tub Hauling Question Triumph 16
PeterK TR2/3/3A Good TR3A tub for $400 Triumph 6
PatGalvin TR2/3/3A Tips for fitting tub on TR3 prepared frame Triumph 23
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
B Spotted a Bugeye tub- Spridgets 0
G Rust free tub in MN Spridgets 2
B TR6 I have to buy a used frame and tub for a TR6..... Triumph 14
MGTF1250Dave T-Series TF Body Tub Rebuild MG 10
S TR2/3/3A body tub tr3 Triumph 5
tinman58 The tub is on the frame! Triumph 11
John Moore Big Milestone! Tub is stripped Spridgets 6
apbos TR5/TR250 Triumph TR5 tub Triumph 1
S Midget body tub Spridgets 8
tony barnhill '63 Tub Epoxy Primed Spridgets 8
C Will older doors/sliders work with MkIII Tub/Top? Spridgets 23
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB MGC MGC-GT tub in Seattle MG 3
J stupid question of the day - dipping the tub Triumph 4
S TR2/3/3A tr3 body tub color Triumph 8
